So I am missing having a hot hatch, can't quite stretch to a cash purchase for a new Fiesta ST without a loan/finance for about 4 to 5k due to imminent house purchase and keep looking at pics of Clio Renaultsport 200's around 09 reg... perhaps with a 7k budget if I was to sell my BMW and pocket a grand from said sale, I could get something nice?
However I know nothing about them. Talk to me, what is good and what is bad, I can try and collate a list of things to check should I go see a few to get a feel for them
Also spec wise... full fat, cup, what's the difference really? I don't want the stiffest version for my usage so if the cup is that, I can live without cheaper plastics I think I read about, it being stiffer, Recaro's etc.
For 7k, you'd be looking at early 200's around the 59/60 plate. After early 60 models, Renault changed some things on the car including changing the rear badge from Renault Sport to RS, including a RS badge on the front, and the suspension components also changed a little bit.
Good points?
They handle like go carts. Stick some good rubber on it, and you can keep up with most things in the corners. Launching out of a corner is quite an enjoyable experience.
Brakes. As long as they are maintained it's like throwing an anchor out of the window.
Bad points?
Speed. If you like straight line speed, it won't knock your socks off. It is fast, but not throw you in your seat fast.
Gearbox. I say gearbox as they are known to crunch in 2/3/4th, but I haven't noticed anything. Saying that, as long as you are kind to the gear changes and do gearbox oil changes as the service book states, you'll be fine.
Flat spot. Some stock cars have them at 2.5k rpm, some cars don't. If you change pretty much anything to do with the exhaust, you will get a flat spot meaning it will need to get remapped. If you are cruising at 2.5k and put your foot down, it will feel like its going to stall. Its horrible.
MPG. For the size and litre engine, it's pants. High 20's low 30's.
Full fat is basically the normal car with the cup pack added on. It means red brake calipers, cup chassis, air con, cruise control, steering reach and rake etc.
Cup is the hardcore version of the normal car. You can differentiate the cup to a FF by looking at the side strips. A cup has black bump stops, while the FF has colour coded bump stops. The cup has stiffer suspension, and some (not all) don't have air con or cruise control. You could have easily spec'd the car when new to be a cup and have all the bells and whistles of the FF car. The difference is also the plastics as you say. A cup has a solid plastic dash, while the FF has a soft touch dash which in my opinion is nicer to feel.
You can get Recaro's in a FF cup, or black or red leather, or the normal cloth seats. Just be on the look out for the bolster wear on the Recaro's.
If I think of anything else, I will post again
