GTA5 has bad SLI scaling, at least with pascal at the moment. I get higher GPS on a single card.
Tried a HB bridge?
I can't play the game without mods tbh and yeah it wouldn't surprise me if it's caused by a mod. Seems to only dip into the 40s when I'm driving very fast and even then it is so brief you hardly notice it. Immediately jumps back to solid 60 when I stop. It stays a rock solid 60 if I'm just walking through a meadow or any countryside areas I would have expected to get dips.Are you saying you get dips into the mid 40's with SLI? These mods must be really demanding. I run a single titan with no mods maxed and i get 60fps apart from in the countryside where grass at ultra dips it into the 50-60 range and if i drive onto a grassy meadow it drops to 45fps at worst in the whole game.
I'm using the Crystal Reality mod.
With hairworks off but otherwise maxed you get 60fps mostly with dips into 53 at worst on a heavily shadowed forest part on witcher 3. Getting 50-60fps is pretty easy on one titan x mostly. An odd tweak on a setting that looks no different to the setting below can help on some games like the division. Do you really need to run max quality shadows and lose up to 20 fps ?
Oh man I envy youWhat mods would your recommend please? Ive been saving this game till I got my titan![]()
Had a change of heart today and I'm cancelling my EK block + backplate.
Instead I've ordered the AQ block black edition in nickel + the active backplate to go with it!
Will make a nice change from EK.
The AQ is more expensive but worth I think especially with the active backplate. Its way more sexy and will perform much better than EK's offering.
I was thinking about ordering from them, but don't want to wait 3-4 weeks. Especially as my EK order was delivered this morning
Still have loads of other bits to wait for though.
Tried a HB bridge?![]()
Damn was hoping you had them as I need to know what thickness thermal pads come with them so I can buy better stuff.
Seen a guy replace the 3.5W/mk stuff you get with EK blocks with a misture of 17 and 11W/mk
He's report temp improvement overall of 10-12C over the EK stuff. I assume he means vrm temps and not core.
Now whether 10-12C lower vrm temps is worth anything to overclocking/stability I will let you know![]()
Just tested it out with 2x flex bridges... so very similar to HB bridge performance.
Everything on Very High / Ultra and Nvidia PCSS shadows enabled.
A single GPU averages 70 FPS - but I see the odd drop to 30-35FPS, especially with time of day changes.
In SLI... it averages 58-62 FPS but there are no drops at all below 58FPS.
Odd behaviour.
Scratch that... VSync had turned itself back on when I wasn't looking... seems to keep re-enabling itself without my permission in NV control panel.
With Vsync off I am getting 130-160FPS with dips to 90-100FPS
No idea how it was getting 62-70FPS with VSync enabled.
Odd behaviour.
I got the Acer 32, 4K Gsync.
Witcher 3 is a completely different experience than what I had at 1440p.
I can maintain 55fps+ with the standard air OC that everyone is doing.
It can be loud but just use some headphones
