Yeah two way sli isnt bad at 18k, the fact that adding another two only gives you another 22% is the shocking bit.
I was hoping for almost 30k as a score.
When comparing scaling you need to use the graphics score not the overall score.
Just shows how **** 4 way scaling is even in a synthetic benchmark, a single titan x gets close to 10k.
even then 4 titans is only 2.5 better than a single titan on gfx scores.
dual titans are what? 805 better so those last two titans have only added 38%.
i do understand but still disappointed![]()
BTW kaap what memory are you using please and would you recommend it?
Close to 10k?
Mine goes beyond . . .
Score - 10502
GFX - 10455
CPU - 10778
The final piece to my water cooling puzzle..
EK-FC Titan X Pascal - Nickel
Your package was sent 16.08.2016 by DPD
Seeing as you have the Strix mobo you should get this
My basket at Overclockers UK:
- 1 x Corsair Dominator Platinum LED "ROG Edition" 16GB (4x4GB) DDR4 PC4-25600C16 3200MHz Quad Channel Kit= £209.99
Total: £218.69
(includes shipping: £8.70)
How come ocuk is so uncompetitive on memory all of a sudden?
This brings me to where I need advice and/or encouragement... I'm considering water cooling but truth be told, I'm a little scared - I've never done a custom loop and to attempt my first with an £1100 card kind of worries me in the event I balls it up.
Damn, that's why I came here - does anyone know when OCUK will stock the titan?
Is there any advantages on buying the titan stock or wait for a SC version, bearing in mind I will be overclocking either way to hopefully 2ghz
You can only purchase it through Nvidia, there is nothing to suggest anyone else will be able to stock and sell the Titan X
Nice looking but ouch on the priceHow come ocuk is so uncompetitive on memory all of a sudden?
And will these offer anything extra apart from colour on my x99 board? I can only find reference on these memory to Z170 boards?
And for less than that money I can get 32Gb of the corsair vengence 3200 with led lights??????
https://www.overclockers.co.uk/cors...00mhz-dual-channel-kit-red-led-my-48i-cs.html
is this memory seriously worth double? Same timings as well.
The Ram u linked is Dual channel so isn't compatible.
Timings tighten down nicely on the ROG kit .![]()
