Vore
Vore
thing is with a high fpi rad like his and 3000 high pressure fans his 240 rad will probably dissipate as much heat as your complete loop.
Care to make a 2k wager (GBP, although it is not worth much) on that assertion? I am always keen for BS bingo, even if I lose, horses for courses, money where your mouth is, come on Greebo, I know you are keen
I was just giving an opinion based on the maths. Plus you gave no info on the make or size of your rads (they might all be 80mm thick) or their fpi so I can't give an exact answer on your cooling power. I only said his "might" give more cooling.
