Ooo, looks like Zen may actually beat Broadwell-E in IPC. This is going to be fun to watch.
I think we have been given the answer to the Ashes benchmark posted earlier in the thread, the clock speed for Zen was almost certainly below 4ghz and most likely in the 3.0-3.5GHZ range.
Wasnt that Zen sample clocked at like 2.3ghz or something in AOTS?
That Zen presentation that stated its running at 3ghz and they clocked the Broadwell the same 3ghz...
What i want to know is how does it scale with higher clock speeds? What speed will we get at release?
Its damn impressive that it competes at 3ghz, but what about 4ghz or higher?
Using Blender to measure the performance of a rendering workload (a Zen CPU mockup of course), AMD ran an 8-core / 16-thread Zen processor at 3.0 GHz against an 8-core / 16-thread Broadwell-E processor at 3.0 GHz (likely a fixed clocked Core i7-6900K). The point of the demonstration was to showcase the IPC improvements of Zen and it worked: the render completed on the Zen platform a second or two faster than it did on the Intel Broadwell-E system.
It's a bit strange that they would downclock the 6900K to 3ghz however? why not clock the Zen up a measly 200mhz to 3.2ghz? will it even scale to 4ghz? if ~3.5ghz is the absolute overclocking limit won't people still go for a 4ghz+ 6700K assuming price is competitive.
I'm going to look at it in more detail tomorrow, but yes essentially I don't believe 2,8 to 3.2Ghz will be the release speed of Zen, tho it might be for the 16 threader, or it might only get another 200Mhz.
It's the big fat chip of the range, the one sucking up the most power, it's likely to be a bit reigned in to keep it within the 95 watt envelope it look like they set for themselves.
Every chip has a zone beyond which it requires very diminished power to performance returns, 10% more MHz could cost 30‰ more power, on a fat 8 core 16 thread CPU 30% more power could result in 95 watts becoming 120 watts, be that as it may it's better to keep the fat one on a diet.
For the smaller chips like the 6 core you could add another 10% Mhz and keep within the 95 watts, the 4 core perhaps 15% for 85 watts.
So I'm really not worried about the MHz on this chart at all, it's not far off where I would have expected the big flagship chip to be, and it is just a test sample.
16 thread: 3Ghz - 3.2Ghz turbo
12 thread: 3.3 GHz - 3.5Ghz turbo
8 thread: 3.6Ghz - 4Ghz turbo
I don't expect them to clock as high as SkyLake or even quite as high as DevilsCanyon. Intel's process is more mature.
Every time when AMD generate hype, the end product is disappointing.
So, let's hope that we see solid facts in the coming months.
I'm still reeling after the Fury X disappointment
Nothing wrong with the RX 480.
There's plenty wrong with the 480.
That's why I've still got a 290x
I would go zen if priced right.
You're right, but it's 1-2 years too late they needed it when they were fighting Gm204 with Hawaii/Grenada. It gets overshadowed by Gp104 today.
