In my experience (not experiencing crashes usually, ever) it's generally to do with overclocks that people are adamant are "stable".
Same thing happened when GTA V came out.
I think I've got a glitch - I can't capture the node to start the hack on the first keypad in the game. Anyone else had this problem?
Just in case you're doing it wrong, you don't start on the one that's highlighted blue but on one of the grey faded ones connecting to it (apologies if you have been doing this).
3440x1440p with i7 6700K & Fury X - only 34 average FPS at the lowest settings!!! That can't be right can it? Anyone else running this resolution with a Fury X or 980Ti? What are you getting?
Why does your sig say 75Hz for the X34? Isn't it 100Hz?
(Offtopic)
How are you lot finding the actual gameplay?
I restarted the game and used the keyboard instead of the controller and it worked although I'm not really sure what I done. Probably is me being stupid.
Have to say the first couple of hours with this game has been total frustration (not the gameplay itself just the pants performance).
I shouldn't have to decrease graphics settings
Why? Nixxes who made the PC port said Ultra is more for cutting edge/ future hardware.
Very high settings with no MSAA and Anisotropic at 16x looks great and plays above 60fps on my (Maxwell) Titan X.
I do have an SLI system but I believe it doesn't really help much at the moment.
The DX12 patch in 2-3 weeks should help though.
