what a crap game lasted less than 24 hours on my pc.
Doing it wrong
You consider it crap and spent a full day doing it?
LMAO.
I'm always up for putting more hours in, hit me up on Steam if you fancy co-op!
LMAO.
Thanks will get through the main game and give you a shout if I'm still hooked!
i wasted about 15 minutes twice so after about 30 minutes of gameplay i deleted it.
I last finished the game back in 2015. Deleted all my saves etc....
Bought the Following and started up a new game. I've completed the prologue and am level 2.
Am I going to be OK playing the Following from this level? The recommended is 12. I read online you actually need the grappling hook to be able to progress in the DLC which at my level I obviously do not have yet.
Patch 1.12 Release Notes
Dying Light fixes:
Various stability improvements (including co-op)
Minor tweaks and fixes
Various balance tweaks regarding Be the Zombie mode
Dying Light: The Following DLC fixes:
Fixed losing buggy parts after playing Be the Zombie
Fixed buggy paintjob replication
Minor fixes improving balance
Anyone ^
Dude, literally 5 seconds on Google:
https://steamcommunity.com/app/239140/discussions/0/517142253860941058/
How do you get The Following if you have the standard base game?
It says on Steam that you "need Dying Light The Following Enhanced Edition" to buy The Following, doesnt make sense!?
Dying light - the following enhanced edition is the base game on the new engine. It doesnt include the following dlc, which you can buy separately or get in the season pass.
Your base game should have updated itself to the following enhanced edition and you should be able to buy and install the dlc on top of it.
At least that's how i understand it...
Not correct. The Enhanced Edition includes *all* DLC for the game. It is essentially the 'GOTY' edition, but with other improvements, too.Dying light - the following enhanced edition is the base game on the new engine. It doesnt include the following dlc, which you can buy separately or get in the season pass.
Yep, go ahead and reinstall it and I'm fairly confident it'll allow you to then buy The Following.That might explain it, I last played April/May last year so presumably the new engine patch will be applied when I reinstall it
