I'm very happy with my new LG (34UC98-W) and the improvment in terms of colour over my old Dell is amazing. I have managed to overclock the pannel to 80Hz and the difference even from 60Hz is very notiable even in Windows.
Thanks OCUK for an epic service as normal
Can anyone recomend any good monitor mounts for these screens? As my current one doesn't work with the new screen.
depends on how much you want to spend but i use the ergotron mx which is very nice
Maybe it's just me i dunno but i feel these monitor sizes are starting to get a bit out of control. 38" is fine from a distance but sitting 2 feet away you're gonna end up twisting your neck a lot i'd imagine.
Any pics?
EDIT*** oops directed at RSR![]()
tbh at 38'' it becomes really nice for couch gaming! hell my TV at home is only 40''
Interesting setup. If you don't mind I'd have a bunch of easy questions for you.In response to another thread I stuck the X34 on an Ergotron wall mounted arm just to confirm it was a good choice. I usually have a 21.5" 16:9 screen for monitoring stuff on the arm up top and the XR3501 usually sits in my race sim setup.
The picture flatters a bit as the two screens have different curvatures so don't exactly match. You are right in that the XR3501 doesn't adjust vertically so the X34 sits a bit high but it isn't a permanent setup more of an experiment. Just like the 40" UHD monitor which ultimately got swapped out in favour of the X34.
Would going from 23' 1080p (95/6 ppi) to 34' 2560x1080 (81/2 ppi) be noticeable as to be not worth recommending?
The only reason is I wish there was a high frame rate UW monitor under 30'.
What's the best curvature for gaming? Do you notice the difference between IPS and VA? And between 100 and 144 Hz? Do you play upscaled on the ZR3501 or just FHD? How noticeable is the difference of resolution?
In my personal preference, they're literally the best and worst that the 21:9 family has to offer but I won't tell you which is which![]()
XR3501 is better for games or even sims with dash/cockpits as there's sufficient curvature to give the impression of some wrap around.
I don't dislike the curvature on the desktop but it's obvious in programs so maye not for CAD/Draw utils. No denying that compared next to each other the XR3501 has a chunky desktop res.
I limit the XR3501 to 120 Hz as that's what it should be! Anything above that is overdriven and adds smear. The 100 Hz of the x34 is plenty for me as well so not much of a difference to me. I tend to limit games to 75 fps anyway to get a better average frame rate.
Fast paced games can benefit from the lower res and higher sustained fps as a result but I'd always prefer an RPG on the X34 with 1440. I did buy the XR3501 with my aging GTX 670 in mind which powered the race sim setup I have so again the lower overall res helped there.
The XR3501 does have a tad more contrast in the darker scenes and minimal BLB but the panel is less consistent otherwise. I genuinely prefer to watch films on it though!
At the end of the day it's average at best but has some redeeming features such being older GPU friendly and great for race games and was -48% discount in the B Grade section. Otherwise I wouldn't even have considered it.
I'm going to try Redout on it later so maybe it'll shine in that Wipeout homage too.
