I know you weigh as much as a packet of crisps, but what pressure are you running them at, and what girth are they?
I'm 5'9 at 81kg, packet of crisps weights a little less
25c@95psi and they've been great from my pov! I commute in all weather around london.
Overshoes are crap. Buy cheap neoprene ones. You'll be wet, but at least you'll be reasonably warm. That or bite the bullet and buy goretex boots.
I don't get cold, it's the wetness that bothers me because I can't dry my shoes by end of day which results in wet shoes on the way home and that is not pleasant
I bought one of the proper tools and it is better than a big screwdriver, but only marginally. A better option I found was new chainring bolts that take a hex each side - easier to get tighter & undo. When tightening the others (with the tool) I damaged the heads as to me they were still not tight enough.
Most of the bolts I found were steel and it's too soft to get anything over 15/20 nM without possibly cutting bigger slots. Alu bolts are stronger/harder but don't see many of them around outside of Shimano.
What have you got/tried?
Of the 3-4 pairs I've tried the DHB Neoprene were the best, they even do an 'Extreme' which I'm assuming would be even better/thicker. They're still all neoprene so will eventually soak up water to a degree. I think the ones I found good were only due to being thicker than the others (BBB's & PX). Looking at the Shimano ones they are neoprene but also have 'print' kinda rubbery designs over the top so I'm imagining (hopefully) that aids in water running off the surface (although I've not tried any yet).
Several guys I ride with use velotoze in the rain but they're an arse to get on/off and don't last very long before ripping as a result. I'm imagining similar to the castelli nano covers I have. I've used them twice in light rain and they worked, but due to the nature of them my feet got damn cold/clammy too!
I have seen the velotoze ones and I think they would work but they do look uber thin!
all the over-shoes I have are neoprene so I guess they're supposed to soak through but even the BBB extreme ones rated at 5/5 for waterproof.
