- 8 Dec 2002
- North Yorkshire
Anyone know where you can buy High 5 Zero tablets in individual tablet sachets ?
Thanks, will check all this and report back. I can flex the rim with my hand and have it contact the pad whilst secured in the drop out. I expect some movement but perhaps there's still too much and they need to sort the tension properly.
Will get a video.
WINTER IS COMING.
Sealed bearing or cup and cone? Is the flex the rim itself (sorted by more spoke tension), the spokes themselves (not strong/tight enough, possibly need new spokes!) or the hub/axle (likely needs tightening if cup & cone, or a damaged/worn hub/axle which the LBS should've spotted).
Wutt-wattage more like?!![]()
Tried to show that there's no movement at the dropouts and that it looks to be entirely spoke related.
I use the underground weather app on my android and it is pretty accurate. Certainly better than the inbuilt & BBC/MET. Although it's occasionally 'too accurate' - check weather, clear, get changed, check weather 15 mins later, rain forecast.Checked about 3 forecasts tonight before heading out for a ride.. Zero chance of rain from all of them.. Got soaked.
Video and report them. Might seem a little extreme but with enough evidence being thrown at Police (by the huge amount of cyclists who now record everything) they'll on eday do something with it. Hate to say it, I'm an optimist!Second one again on the approach to a bend a guy passes and again a car comes into view "**** me that is close"... then I spotted the trailer. Slammed the brakes on and the trailer cut across about 6 inches in front of my front wheel.
Email Wiggle and ask, or look on ebay? Could even email High5 to ask!Anyone know where you can buy High 5 Zero tablets in individual tablet sachets ?
Yeah I would say that's spokes (but I'm no way an experienced wheelbuilder). What does Saytan think?Tried to show that there's no movement at the dropouts and that it looks to be entirely spoke related.
LOL! Amazingly one of the few things I've not done to Wiggle (but abused them in many other ways...!)Just order and returns tons of individual items to Wiggle with free postage. Winnar
This is actually how I stocked up recently. Not on purpose but due to being incredibly disorganised.
Move out and take ownership of the lane before the bend so they cant overtake dangerously and then pull in afterwards
googling round, it seems the aeolus wheels are noted for being *difficult* in regards to spoke tension. Unless your LBS's wheelbuilder is particularly noted/experienced with low spoke counts etc (and most learned to bosh out 32 spoke open pros on 105 hubs) they may not find it particularly easy
it might be worth seeking out a local specialist wheelbuilder
I'm sure I came across a website/blog of a wheelbuilder who used a guitar tuner and/or a tuning fork to perfect wheel tension.What kind of tone comes out when they are plucked? spokes "ring" higher as they get higher tensions.
There's just some idiots on the roads who'll overtake regardless of the road and if it's clear or not. Unfortunately you can't tell who they are until they're squeezing past you in semi-primary with oncoming traffic hurling abuse. I'm actually getting a little more cautious of taking primary now on some of the twisty A roads around here & taking a 'sub/semi-primary' position as some of the idiots drive too fast to stop. I'm actually looking forward to lower light conditions so my lights slow people down more.I'm sure the 10 seconds they saved was worth the fright they got though.
Roady, it is tempting but I can't really be bothered with more stuff to attach to the bike / charge for each ride. I guess the Fly cameras would work quite well for me but they are too expensive for the use I'd give them.
Talking of expense... I've pretty much decided on a Fenix 3 when I get back from my trip. That is of course unless anyone can give me any reason not to from a cycling perspective?
Fenix 3 loops superb, but if you're using it for 75% or more cycling it's an expensive compromise when a Forerunner & something cheaper like a 520 (i.e. one for each sport) could give you more features.
Not sure, it doesnt look right though, thats a lot of movement for a relatively small force
what kind of spokes are they?
What kind of tone comes out when they are plucked? spokes "ring" higher as they get higher tensions. if there are the same number on both sides, the drive side should ring substantially higher than the non drive side. Usually the drive side rings a bit higher than a similar front wheel, while the non drive side is a bit lower.
all the spokes on a side should ring close together too
