http://www.pcgamer.com/gears-of-war-4s-campaign-will-have-split-screen-co-op-on-pc/
MS must really need our money its also got split screen co-op !!
Take a positive and make it into a negative why don't you...
Quick question, if I buy the £49.99 version that comes with Xbox One and W10 keys, could I in theory give the Xbox key to my brother, and I use the W10 key on my PC, and both play co-op together... essentially 2 copies of the game for £25 each...
Play Anywhere doesn't work the same like Quantum Break did. Once you buy the game digitally its tired to your account to access on both platforms. It doesn't give you a separate key to redeem on Windows 10.
So no, that wont work.
Am i right on saying i have to get this for £49.99 and i can play it on either xbox on PC....
yet the version for xbox is £35....
Not sure on the 50 notes...
The other option is to buy from Singaporeended, thanks though![]()
It's because console games are traditionally higher priced, and I guess they don't want to be undercutting their faithful console gamers?
Plus if it was cheaper - Wouldn't it have to be cheaper all around, as buying one gets you access to both PC and Xbox One version now.
So savvy console gamers would just all buy the cheaper PC version to play on their consoles.
You would think they could just price it £10 higher in shops than for a digital download though, as most consumers would understand the cost of pressing a disc, manual, producing a game case and shipping them out to stores is considerably more than storing it on a cloud server for people to download.
Go to Microsoft site
Change region to Singapore
Buy $70 Singapore credit and redeem to account
Go to xbox site
Go to gears of war 4
Buy with credit
Will still only cost you £40. That's the way I did it
Does anybody know if you will be able to install this on my second drive ? as my main windows ssd if getting full.
Forza horizon wont let me move it too my 2tb HDD so was thinking this might be the same![]()
That's what I don't get with Microsoft, I like that these games are coming out on the PC but they sabotage it with very high prices compared to steam
