- 21 Oct 2011
- ST4
Baseball bat. Just make sure you also keep a baseball handy too.
You are still only allowed to use reasonable and proportional force.
ex:
If someone breaks into your house and you clock them on the head once with a blunt object and knock them out I'd be VERY surprised if any court in this land will find you guilty of a crime. (Reasonable force)
However if you decide to batter them into a coma then good luck in court, because you're gonna need it!
Ohh and your stabbing them in the neck with a 12inch knife WILL land you in serious trouble unless you can prove that he posed a threat to you or a loved ones life. ie. he came at you with a weapon
I'll just grab a metal bar next time as well due to we make implants from them so can easily say I picked it up after he challenged me the next time
Am not being funny but if an intruder is in your home what is reasonable force?
You don't know if they are carrying a weapon, you don't know what there motives are, are they there to rob you or kill you.
I don't give a flying ****, you break into my house you getting it no matter what the law says.![]()
Keyboard?
queen wasp
My license isn't very sharp at the edges. What do you suggest? Smother them with it?
kubotan legal if on your keys I have one wife has one ect
You can use reasonable force to defend yourself. Is planting a baseball bat / metal bar considered reasonable? Probably more on the side of pre-meditated assault, if you injured them with it.
I know someone on the forum who can get you a mac10 in seconds!
