when i bought my super sports they were about £120 eachPs4 is fine at £100. Super sports are £150 so not considering that at all
They'll need some mileage on them to start giving their best. The steering feel on the MPSS is it's strongest point, yet the weakest point on the CSC5 so it should be much better with the new tyres.
I have Conti SC6 on my Z4 and in performance terms they are very impressive, although not so much in the cold. They are now getting a bit low on the back (4mm ish) and obviously the weather has turned and the wet weather performance in particular has gone from absolutely staggering to fairly average. When new I took the car for an Evo Triangle lap or two in torrential rain (but 10c+) and had no traction issues. In the cold and wet this week, I couldn't even have the car in Sport+/M because pulling for an on-throttle upshift would light up the rears.
Wear is about average - certainly not up to the claims of the MPSS longevity but far exceeds what people say about them only lasting a few thou - mine have done at least 10k now of quite spirited driving and still have a while to go on the back!
I literally have no idea what tyres to put on the 535d. None at all![]()
I had those Dunlops on a set of wheels I bought a while back. Granted, they were old and probably past their best, but they really were shockingly bad in cold / wet conditions. After a couple of sideways moments I changed them, even though they had around 4mm left.
What would you chaps recommend at roughly £100/£110 a corner?
I have a E93 330D which will need tyres all around. Currently have run flats which are noisy, uncomfortable and crazy expensive so I want to get rid of them.
Front: 225 35 19
Rear: 255 30 19
Front: 225 35 19
Rear: 255 30 19
Looking at tyres for the Lolvo (V50, 205/50/17)
CSC5 still gonna be the best bet for a mile muncher?
