2666Mhz oc and dual channel might be ok for now but its a little too close to the point where performance starts to seriously suffer across a wide range of apps and games. Anyone running a 6700k l, especially if overclocked, with 2133Mhz ram is most definitely holding back their system. (or course its well know that running mem much above 3000Mhz shows very little gain outside of benchmarks)
Notes Concerning the Tested AM4 Platform and Ryzen Sample
As per the publication, there are some important notes that need to be taken into consideration with these results:
The sample used to accertain these performance metrics, was an engineering sample with stepping A0, on a platform with unfinalized features. The sample part number is 2D3151A2M88E4.
The A0 stepping contains two IPC-inhibiting bugs; one relating to the micro-ops cache, and one relating to the SMT implementation.
Despite these present bugs, the features were enabled. Evidently, this is going to hinder performance by an unknown percentage.
The AM4 platform currently has issues detecting SSDs and also failed to detect an NVIDIA GeForce GTX 1080.
The Ryzen sample's memory controller suffers from instabilities with system memory at data rates above DDR4-2400, despite the fact that this specific sample supported DDR4-2666.
I'd probably read the article before quoting it if I was you ;
AMD has already publicly revealed, as of the New Horizon live event, that stock clock frequencies for production silicon Summit Ridge SKUs, will start at 3.40 GHz. That represents a 7.9% increase over the sample used here to gather the results. Zen's memory controller will also be capable of detecting DDR4-3200 modules, which will give the final product 33% more memory bandwidth than the sample here could take advantage of.
Ultimately started as an observation is now degraded into treading on egg shells, trying to explain how memory frequency and IMC strength are intrinsically related.
Joy. Lessons over![]()
ignoring the small fact that I have linked 2 Z170 based motherboards , 1 can clock the ram higher than the above - based upon quality of the parts used; ergo IMC is only 1 part of the overall system.
apparently you have limited understanding in that.
And here we go.
It's only truth if it's positive.
That article is an opinion piece.
Also, it says "Detecting" not running.
Averaged across our seven games, we see a 2% boost in average FPS and a 3% boost in minimums going from DDR4-2133 to DDR4-3200, which is relatively impressive given the settings we were playing at (maxed out at 2560x1440, typically).
Overall, we've found that DDR4-2666 memory is definitely the optimal choice in terms of performance and value on both the X99 and Z170 platforms, and while faster memory will benefit the Z170 platform, it comes at a cost that likely isn't worth it for gamers when the money could go to other components like CPUs and video cards.
And your `facts` in regards to Ryzen are only facts if they are negative.
ryzen is doomed , says martini , as it doesn't have quad channel - forgetting that kaby lake is dual channel as well
And I linked to the cheapest Z2170 boards that both put 3866MHZ DDR4 support there.
So...
So...
lol.do you know how to read? I have said , 5 times now Z170
you are linking a completely different chipset. remarkable.
mm... a cording to that its the same specification as broadwell, other than dual channel.
I think for people to lay down a number and insist it can't go beyond that is not a smart thing to do, to be polite about it.
Even this argument that "AMD hysterically have weak IMC's" is a bit off context, Phenom II CPU's had an IMC bottleneck, which was cured by overclocking the IMC, which everyone did, including me, i don't see how that's relevant here.
Piledriver was rated at 1866Mhz, maybe thats more relevant here, i had two of those, i ran them both with 4 sticks of RAM at 2400Mhz, thats not weak at all.
Most of that is down to ASUS T-Topology trace routing as to the differences. It's a totally different argument.
What use is optimising signal integrity if the memory controller can't handle the speeds you're working towards.
The obvious answer to that question is...nonelol.
its not a different argument , as you are now beginning to understand - IMC can go so far , but with a high quality motherboard and chipset , can take the ram that bit further
