There was a camera like that on here, but I can't remember what it was called and cba to search.
Useful post
I realise this thread is almost a year old, but thought it perhaps better than making a new one.
What options are there currently as a Dashcam alternative for a bike? I have a GoPro, but would like something more permanent, wired into thew power, comes on with the ignition and records on a loop.
As I say, basically a Dashcam, not a helmet cam. Any decent options? Obviously it would need to be quite discreet.
Is there anyway to destroy the content immediately like mission impossible.
With any of the cameras.
Myself, I'm trying to find a 720p / 1080p camera that I can helmet mount that has decent battery life. Was looking at all the variants of the Hero but not sure what to buy yet.
Nope, those that have a quick format are easy to get all the data back from.
What do you class as decent battery life? If you want over 2 hours, forget it. You'll have to power it with a powerbank or carry extra batteries.
You could rig some electromagnets either side of the camera and run them off a switch
Thinking out loud here but what about those wifi sd cards? Do they store data on the card and transmit it or do they send all data wirelessly?
That's why I don't like cam's, they can be used against you in some cases.
