Being without the car for so long already have you not considered putting it into another garage?
It's currently without a steering rack so it's not going anywhere unfortunately
I'm going to give them until Monday when he's hopefully back in, if nothing is happening then I'll start getting arsey. I get that as a fault claim, I have to compromise to a degree, but this is taking the mickey a bit
The BMW just couldn't keep up with the mighty AMG eh?![]()
Older model Z4? If so that's*something*you should pretty much expect to happen in your ownership if the water channels have not been kept clear for its*whole life.
Yup.. go on z4 forums a few members can relocate it to the boot so you don't get the issue again. It's not that expensive to fix anymore and can be done for under 800 with refurbished motor
Depends if*you enjoy it or not even with the issues. The motor is just an age thing that's got a decent chances of going wrong on these now. Something I accepted when I was reading up*on them before I got my first Z4.
In my opinion you cant get a better roadster for the price/age.
As I mentioned earlier, the headlights had some condensation, which appears to be quite common. As it turned out, the lights were completely shot, failed the MOT, and had to be replaced for brand new ones! Result!Probably, only had it for a year and a bit, just been issues after issues with mine unfortunately, Luck of the draw and I lucked out.
The bushes need replacing
Oil leak, Mechanic suspects its the Valve Cover
Atrocious Interior quality (Rattles & Squeaks)
Roof Motor packed in.
