If you love a warmth representation of the music that you listen to then yes.Is the Valhalla 2 and modi multi a better fit for the 650's than the jotty?
Depends on your preference. Both have the typical Schiit sound, lean, mean and a bit aggressive. Valhalla 2 has better depth, spaciousness while the Jot has more immediacy, speed. Bass on the Jot is much more defined, hits harder, cleaner and tighter. I didn't find either particularly warm. Both are about on par for detail.Is the Valhalla 2 and modi multi a better fit for the 650's than the jotty?
I wish lolAre you on commission?![]()
I'm considering (your) vali to a vali 2. Can you do the thing with the words where you compare them?Depends on your preference. Both have the typical Schiit sound, lean, mean and a bit aggressive. Valhalla 2 has better depth, spaciousness while the Jot has more immediacy, speed. Bass on the Jot is much more defined, hits harder, cleaner and tighter. I didn't find either particularly warm. Both are about on par for detail.
The Jot has a metallic, treble that bothered me but it's an improvement over the Magni models! overall the Jot is an end game amp at a good price and I've been tempted to order one for a while but I'm going to see if there's an Asgard 3 as the seem to do treble better than their other amps a long with the Vali 2.
The Jot is a really fun amp!
Sorry for late reply I don't check forums as much, been addicted to Ark on PS4 LOLI'm considering (your) vali to a vali 2. Can you do the thing with the words where you compare them?
Well I am in no rush at the moment!Sorry for late reply I don't check forums as much, been addicted to Ark on PS4 LOL
The Vali 2 is a bit cleaner, more spacious resolving and has a bit more of a laid back sound. I find the original Vali more musical, more involving. It's probably the most fun amp I've tried along with the Bottle Head Crack for the HD650. The Vali 2 is the better headphone amp technically but if I see another Vali 1 I'd snap it up asap.
The Vali 2 is reoslving musical and engaging amp though, I just find the original Vali pretty special in regards to fun. The Vali 1 has a roughness to it's treble although not as bad as the Magni. Vali 2 has one of the best treble I've heard from Schiit, prob the best.
I'm still blown away how much better they sound driven this way compared to something like an O2 or your average tube amp, etc.My first "real" pair of headphones came yesterday... quite underwhelmed really. Am upgrading from a Sennheiser PC360 and although I can definitely hear the highs are clearer (slightly) but seems to lack bass. There just doesn't seem to be much of a difference.
Am aware audiophiles will say I'll need more than a week to adjust but I'm a bit skeptical atm.
Running it from a Xonar Essence STX and am considering a MODI 2 with either a Magni 2, Valhalla 2 or just the Jotty. Any advice? I do like the sound it's giving off atm but then I do read that the Valhalla isn't your typical warm tube.
, I don't really consider myself an audiophile but something I will say for a fact is when it comes to headphones it really does take a while to adjust to the new sound signature, hand on heart, and a week is genuinely a good amount of time, just forget about your old headphones for now, just accept the new ones as they are for the week, then put the old ones and report back
, I remember years ago when I first upgraded to my B&W speakers from cheap pair of floor standers, I was looking for the bass under the sofa, couldn't find it, but in the end grew to love their refinement and more apparent mid-range, now all these years later I find then too bassy and am looking for something with more clarity and tighter bass!
Is that directly off the STX? IMO most if not all soundcards can't deliver the peak to peak voltage required to bring the 600 series to life - needs something with a minimum of +/- 9 volt rails IMO and around 12 volt better.
Otherwise the bass collapses or becomes poorly controlled and treble becomes bland.
EDIT: If you really want to hear what the 650s are capable of you need a balanced output amp with active groundI'm still blown away how much better they sound driven this way compared to something like an O2 or your average tube amp, etc.
Not sure I'm the best to person to answer this after my last thread, I don't really consider myself an audiophile but something I will say for a fact is when it comes to headphones it really does take a while to adjust to the new sound signature, hand on heart, and a week is genuinely a good amount of time, just forget about your old headphones for now, just accept the new ones as they are for the week, then put the old ones and report back
Yeah directly off it and set to high gain, +12dB. I thought that but have read countless people say that the STX can drive these fine.
Yep 650's are one of those headphones that just keep scaling
