Vape goo do 400ml for £30. Some of the flavours are nice, think they are/were closed until they became TDP compliant but should be reopen soon.
So glad I got 200ml of their Blue Slush a few weeks back, sucks they are closing![]()
Never heard so much positive feedback on a device before!I'll check them out in a couple of weeks then. Hopefully they'll be up by then.
GoldenGate liquids are great too. Great range of flavours and the owner is a damn nice guy.
That really, REALLY sucks! My favourite distributor by far. There Blue Slush has been my all day vape for months![]()
Sigh...
In other new, ordering the Troll RTA tomorrowNever heard so much positive feedback on a device before!
With the closing down of jackamoo, what are peoples go to budget juices now? I tried rejuiced in the past but haven't been impressed with anything I have tried recently.
Thanks. I've bookmarked their site. Next time I place an order I'll try them out
By the way I'm still not sure about this whole VG/PG ratio stuff. I've bought 60/40 and it seems to work OK. Just wondering what the difference will be with 70/30 on Golden Gate liquids? I have no idea.
Sigh...
vg= thick, gloopy and cloud making
pg=thin, runny and flavour/nic carrying
ratio depends on preference, but 70/30 is a pretty common ratio for the "cloud chucking" stuff. although you may find on smaller tanks or in the cold weather it doesnt wick too well. likewise too thin may well end up leaking.
i tend to find as a general rule 50/50 works in anything, and 70/30 is preferred for rda's, and big tanks.
there wont be much between 60/40 and 70/30.
.DIY e-juice.
DIY e-juice.
A mod needs to pin your posts or something mate. The amount of times you get asked how to go about this is quite mental xD
Someone be a diamond and re-post my DIY guide for me please. I'm at work currently.
Riiiiiiiiight...
I think you're looking too hard into this in all honesty, mate.
1) Go on Vaping Underground (http://vapingunderground.com/forums/diy-e-liquid-recipes.50/)
2) Find a recipe you like the sound of, ideally using all FA concentrates.
3) Buy supplies & concentrates needed.
4) Mix 100ml of said recipe for pittance
5) Find another recipe, rinse & repeat.
I fail to see how buying some of their ready made juice is going to be a better way of trying out flavours, haha.
Get HICs tasting notes from his website for free, that has every single FA concentrate, free of course: http://www.hicsmixes.com/notes-etc.html
__
E: http://www.lediypourlesnuls.com/ for clone recipes.
PG/VG/Nic (72mg PG) - Darkstar Vapour // get it all separately. It takes 30 seconds to mix up your base by weight (using scales).
Concentrates - FlavourArt.co.uk, Vapable, thee-cigshop.co.uk // personal preference. I swear by FlavourArt (free of any nasties) and imo they're the best concentrates out there for accuracy of flavours. NOTHING beats their Tiramisu.
Bottles - ibottles.co.uk
Scales - http://amzn.eu/fpsEU4q
Calculator & recipes - http://e-liquid-recipes.com/
_____
Initial cost may seem a bit high but I promise you, once you get a few concentrates you'll have so much fun coming up with new recipes yourself. It's by far my part of vaping. Hell of a lot cheaper too. You're talking ~£5-6 for 100ml.
I'd recommend something fruity to get you started (holla if you need some ideas), plus they don't need any time to settle/mature. Straight in a bottle, shake it up and you're good to go.
PS. Someone should sticky this, forgotten how many times I've typed this out in here!
