Or as Gibbo said teatimefrom OC3D
"Pre-orders are expected to go live later today at 6.00pm GMT. "
as i Said without saying it out right, Supper time!!!!!![]()
Fair point. I guess we've all got 5ghz in our brains because of these kabylakes been touted around these forums.
from OC3D
>.<Or as Gibbo said teatime![]()
haha..........what about motherboards, will they go live with pre orders at the same time?
>.<haha
I still think tea time is 5pm bang on . hahaha
16gb DDR4 I could have had for less than 100 quid last year.WOT
When i got my first set of G.SKILL 3000mhz (16gb) it was £269.
Got my last 32gb (8x4) corsair lpx 3000mhz for under £200.
People saying 5.1Ghz on LN isn't that good. Bear in mind this is the 8c/16t (i.e. the equivalent to intel 6900k). On HWBOT the highest 6900k appears to be 5.2Ghz so not that much different
i brought corsair 16gb quad for 68 quid then16gb DDR4 I could have had for less than 100 quid last year.
I'd expect so as it would be daft having only CPUs available!what about motherboards, will they go live with pre orders at the same time?
Gibbo said 18:00 in the celebrating thread.
just a bit of a gag . everyones Tea time is different
But it won't stop people complaining, a chip can do 4.9Ghz on air, 5Ghz on water and 5.1Ghz on ln2, or 4Ghz air, 5Ghz water and 8 Ghz LN2, or basically any combination.
Most importantly, if you won't be using LN2, LN2 overclocks are entirely worthless, as it tells you absolutely nothing about air/water overclocks, they can be literally 50Mhz higher or 5Ghz higher than water.
But on water you won't get anywhere near 1.85v though.But it won't stop people complaining, a chip can do 4.9Ghz on air, 5Ghz on water and 5.1Ghz on ln2, or 4Ghz air, 5Ghz water and 8 Ghz LN2, or basically any combination.
I don't for one minute believe that Intel will do it because they're too money grabbing but they could if they wanted to position 6950X against 1800X, 6900K against 1700X, 6850K against 1600X and 6800K against 1500 etc.
