- 5 Sep 2011
- Surrey
Yeah, he was right about 2666Mhz RAM being the absolute limit on Ryzen, he was right about nobody being able to OC the CPU over 4GHz, and when the time comes I'm sure he will follow through on his promise to give away his computer to the first person to OC the RAM to 3866Mhz or higher![]()
Actually, I was right about everything. Some just don't have a grasp on memory overclocking. I said 4Ghz OC would be the limit on air, which is correct. I said memory overclocking was seeing as much as 30%. 2400 + 30%. Which if you're capable of doing the math, is pretty much bang on the maximum obtainable frequency.
You can always buy the high bin kits yourself and post up some memory overclocking results as I will be doing - instead of back chatting. This is probably a good idea.
Also, yes - if you can show results running 3866mhz in HCI MemTest with 2 or more DIMMs, I'll post you my rig
