Incorrect. It is cooled using an AiO filled with tears harvested from Intel board room execs.My source in R&D just informed me that there's a specially binned 1900x in the works capable of 5.0Ghz with no cooler at all.
anyone pre ordering before benchmarks out is kinda puzzling.
How is it puzzling?
There's nothing wrong with pre-ordering... two scenarios:
- The benchmarks get released, performance is good, you have a CPU while other scramble trying to get one - sit back and smoke a cuban cigar
- The benchmarks get released, performance is bad, return the CPU unopened and get a refund
It looks like shipping has gone back nearly a week already (2nd -> 8th) purely based on pre-bench pre-orders, so this will only go back further if performance is good
Indeed. Already ahead of a lengthening queue.
Aren't reviews hitting 28th anyway? Or has this moved?
Will have to wait until Ryzen 5 or Ryzen 3 is released, as that's more my price range I'm afraid. Although if you want to send your free sample out when you get it, I'll give it a go.
@Gibbo Can you confirm pre-orders ship on the 2nd?
RyZen 1800X apparently smashing Cinebench R15 world record on LN2
http://hothardware.com/news/amd-ryzen-7-1800x-52ghz-on-ln2-smashes-cinebench-r15-record
Critics may feel differently about using LN2 to significantly overclock it, noting that it doesn't seem all that impressive when Intel processors can do the same with much cheaper cooling solutions. However, AMD is touting a high instructions per clock (IPC) for Ryzen, which typically means greater efficiency at the expense of higher clockspeeds. According to AMD, finalized silicon for Ryzen boasts a >52 percent IPC improvement over previous-gen parts.
Makes sense, I'm guessing the ETA has just shifted for new orders as they've sold their intial stock allocationI asked via the customer service forum and basically purchase orders placed Wednesday when the ETA was 2nd March should be fine as that's based on the first/latest (at the time) stock order. Now that they've probably sold 1000 Ryzen CPUs, another stock order has been placed so any new purchase orders placed will use stock from that new stock order with the date of 8th March.
Would be good to get a confirmation from @Gibbo though. But assuming they got the stock for 2nd March orders, then they'll be released.
