Memory latency might seem high but everything else is pretty mind blowing.
Compared to my 4.2Ghz 5820k on 2400Mhz memory(it's 3000Mhz, worked at that for a while but stopped booting until mem speed was dropped
 ), the L2 cache of Zen literally doubles performance, L3 has 50% higher read, 3x the copy and marginally behind on write. L1 is a little slower on Zen. Read though... wow. My quad channel 2400Mhz is getting 46.9GB/s, Zen with 3200Mhz is beating it. Max theoretical numbers are once again popping up showing AMD smashing to pieces anything Intel has on efficiency. I don't have l2/l3 latency as trial version hides that, L1 read(so read might be great), also memory write/copy are hidden but there is no reason write will be monumentally higher than read, nor is it more important anyway.
At 2133Mhz Zen appears to have almost 100% bandwidth efficiency, Intel is at around 75% on Skylake/Broadwell, at higher memory speeds efficiency reduces for Zen it appears and Intel. Max theoretical on my system is 76.8GB/s and I'm getting 47GB/s, around 61% efficiency. 3200Mhz dual channel has max theoretical bandwidth of 51.2GB/s, so 47.7GB/s is still 93% efficiency.
Zen doesn't have a weak IMC< it has one of the best IMC's ever seen, with incredible bandwidth.
That bodes badly for Intel when it comes to APUs later this year. AMD has the HBM for super high margin products and Intel memory cube seems to be AWOL(and much more expensive and higher power, maybe it less use for mobile where Iris pro is aimed), but in more mainstream pricing AMD is looking like it will have 20-30% more memory bandwidth for their APUs at any given memory speed used. AMD APUs are going to absolutely destroy Intel on igpu performance.
