How much time are they going to give people to cancel their pre-orders before shipping orders![]()
The gaming is nothing short of a let down.
But the performance is there, it's looks like a fixable problem.
Performance does seem hit and miss - in some reviews it is more competitive and in some others its not.
SMT causing performance regressions in games is a tad worrying though.
if smt is a problem gaming I would be interested to see what its like disabled, running just the 8 physical cores would produce lees heat and use less power so might even get higher clocks
Sad part is that AMD is probably going to lose an immense amount of those pre-orders due to their inability to fix the issue before launch (could be a hardware limitation as well).I honestly don't see the problem.
I am impressed that the "leaks" were pretty spot on, but suspiciously so. As for gaming performance, here's clearly an issue that needs to be sorted, I expect BIOS updates and the like will resolve a lot of it. Also, like a previously said, if your PC is purely a gaming machine, I don't understand why you would go for an 8/16 CPU setup right now anyway.
