So Martini is right, it is a problem with SMT in Gaming......
AMDs version of hyperthreading.
Sure but it's still getting great reviews even with self inflicted below par gaming performance. First thing I will be doing is disabling SMT on the 1600 if it's not fixed by then.
What they entered robotics now??![]()
That's more like it. Hopefully this can be fixed (I assume Microsoft hasn't patched any Windows versions for AMD's SMT implementation yet) and it also indicates that the 4 core and 6 core version will be fantastic bang-for-buck compared to Intel (tiny loss in gaming performance, way cheaper, and better general productivity). Hell, if the 4 core and 6 core versions clock slightly higher they'll probably be on par in some games.![]()
SMT definitely causing AMD to lose FPS in games. Lower latency RAM also seems to help a lot.
might go this way myself, when I had a 17 920 I disabled ht to get higher clocksSod it, 1700, disable SMT and suddenly you having a competing gaming CPU.
Don't forget this is AMD's first attempt at SMT/HT, took Intel many years to get it to where it is.
Think I might go for a 6800k. Only £50 more and I can have it tomorrow...
I get what you are saying - but AMD should have seen that and said for reviewers to bench gaming without SMT on in the first place.
I suspect many of the worst gaming results are with SMT on. Plus the whole debacle with the rushed motherboards,etc. The whole point its "another few months and performance will be fixed" scenario.
Many of use enthusiasts might give AMD a bit more leeway,but the average Joe won't and will dismiss Ryzen as a whole for gaming anyway even if things are fixed.
Yes,AMD will do far better with this range in general CPU sales,but the problem is they will also being loosing sales to Intel.
You sound like you've changed your tune since yesterday. I wonder if drunken master still thinks I'm 'utterly' wrong![]()
be gone with you get out of this thread![]()
If i was you and not in a real rush wait a while see how things settle re memory / bios and this SMT thing
