Had my despatch email for both now![]()
When did u pre order yours out of interest Alexp?
The thing is he plays a lot of FSX which is an ancient game and I'm worried he'll get terrible performance in it. Will have to think things through, can't believe AMD didn't have all these things sorted ahead of time.Hold... it has teething problems, some reviews are getting excellent gaming performance, IMO once all the issues are fixed that will be the reality of the CPU.
Still no despatch email here eitherOrdered the 1700X with the ROG Crosshair
Thanks for the info, shame that you preorder a bundle and end up losing out.Got the same on order. called up to be told no more ROG boards. Tiny batch coming tomorrow and another batch early next week with hope of clearing pre-orders by mid next week.
Will be keeping my order with here though due to the 48 hour ASUS turn around warranty.
So to summarise things...
Reviews are all over the place, for Gaming and even for non gaming tasks
You need to run Windows in High Performance settings to make the most of the chip
SMT is a hinderance until its patched correctly in windows, Patch due in a month or something?
Motherboards are still being worked on
So once the above gets sorted, the chips would benefit from being re-benched, something most reviewers wont do for whatever reasons, AMD has another stain on its release history... seems history often repeats itself with AMD launches
But i maintain the performance is there, definitely, just need to be patient and wait for the fixes to unleash it.
Will the 1700 be a good choice if you are not bothered about Gaming?
For sure. Beats equivalently priced Intels in most productivity tasks. Only gaming looks a little dicky at the momentWill the 1700 be a good choice if you are not bothered about Gaming?
Sorry, but whats the OS issue?
Yes very much so you have more options. If you want more just clock it up to 4ghz. If not leave at stock it comes with a fan. You could even reduce voltage a little and make more energy savings with it if you wanted.Will the 1700 be a good choice if you are not bothered about Gaming?
Think I'll wait a few weeks and see what MATX and ITX motherboards appear/get announced before making a decision.
