Replaced the tailgate gas lift struts as the old ones had died completely, meaning I had to lift the whole weight myself and hold it open. It's a remarkably heavy tailgate.
Paha
I think they all are
Thanks, just this moment checked talk ford and said about 5.5L. Annoying that I can buy some for £18 but it's 5L only. Already have some in the garage is it ok to mix oils even though they are same 5w30?Google suggests not. 6.4 litre capacity on a clean engine, and you typically need about 5.8 litres.
Depends what it is you have in the garage (whether it is an approved oil) and how old it is etc.Thanks, just this moment checked talk ford and said about 5.5L. Annoying that I can buy some for £18 but it's 5L only. Already have some in the garage is it ok to mix oils even though they are same 5w30?
Which I'd imagine would get boring after about 17 minutes.I have a rattling noise which was bothering me in the MX5, I found out that the baffle in the mid-box has come loose. So at some point the mid-box will get cut out and replaced with a bit of pipe.![]()
If you have bought 5 litres of Shell 5w30 and you have some 6 month old Castrol Magnatec/Edge 5w30 in the garage to top up 500ml - it won't make any difference.
If you have some Tesco oil 5w30 part synth from 5 years ago which had been opened and has cobwebs all over it - it's probably best to just by 2 x 5 litres of the 5w30 oil and keep the rest for topups or next years old change.
I Just fitted a new head unit that doesn't have a CD slot for the first time since CD players were available.![]()
I also ordered a bonnet cable from them at the same time, since apparently the mk4's cables like to snap. Not been arsed to fit it yet though.Thanks - ordered!
Did you follow the correct procedure for all of the flushing/refilling and such of the Powershift box?
I don't think I'm brave enough / have enough arsed to do it myself!
(I have to provide photos/recpts to evidence the work I have done).
