Just to add my settings with a revision A03:
Monitor:
Brightness: 40%, Contrast: 75%, R:96 G:95 B:96
NVidia control panel:
Brightness and contrast 50%, Gamma 0.63, digital vibrance 65%.
Does anyone know if OCUK have the A04 revision? OCUK price isn;t the best but might trade that off if they have the latest revision.
.Prices are silly. I struggled to get mine for £499,ocuk have it on offer for £569 I think![]()
thanks mate.Remove all leads including power for 2-3 minutes then start it up with nothing else connected or connected to a different device if possible and see if you can disable deep sleep (under others option at the bottom) in the OSD before connecting a source (you might need to keep pressing the OSD button closest to the power LED on starting it up to bring it out of sleep mode).
EDIT: Hopefully that wakes it up again - you might find you need to change which DP connection on the GPU or even the lead if it continues to happen after disabling deep sleep.
