Yeah,but in the end each person has the right to judge it based on what they use it for.
Like I mentioned,I might be doing an R7 1700 build for a mate who is more a casual gamer,but uses his rig to do more non-gaming stuff.
I think it's more a case that many of us (including you I thought) have been around long enough to have seen a new architecture design launch (IIRC AMD's last was 2011 and Intel's was around 2006 lol) and know that these type of things are to be expected.Its getting increasing annoying that some are taking zero criticism for these CPUs - everybody who does not play games which run well on Ryzen or are not the latest multi-threaded monsters should shut up even when its obvious it does fairly poorly in some major titles.
That's pretty much a given really, the current BIOSes are essentially developmental prototypes that got released due to motherboard manufacturers not having enough lead time before the rushed launch to actually get a launch quality BIOS done (AMD's fault ofc), and MS will have to fix the scheduler issues as they cannot support only one CPU manufacturer (and post Vista CPU extensions are quite dependent on O/S support) but they too were given limited time to get it done.Now we are living in the hope MS will fix the scheduler and the motherboard companies will fix the BIOSes.
I don't have a Ryzen CPU or system yet mate. Shocking when you consider i work for AMD.![]()
That said, i should get a 1700 on Monday, but looks like i might be waiting a while to get a Asus Crosshair VI Hero motherboard.
Did they?
Pretty much everything I've seen from them compares Ryzen against the 6900k.
You can say that but when Bulldozer launched,Asus was the best OEM by far for motherboards - Gigabyte due to its lack of LLC,meant they sucked!! Mates with the Asus 970 motherboards had very few issues,and MSI motherboards could have issues with the VRMs.
The thing is AMD still controls the launch,and they need to manage these things,even if it means Asus gets no exposure at launch and even the same with the Windows 10 patches. AMD knew they would come in a month,so again its in their power to delay the launch a few weeks,so everything catches up. Remember,I am the one who managed to find that set of comments in that review and post them here,regarding the patches in a month or so,so at least we hope in a few weeks things might look better.
So AMD's heat spreader adds 1-3 degrees of heat, Intel's adds what, 20-30 degrees? Ha.
CAT - the mobo makers have had at least 1 YEAR to get this right! not 3 weeks
Agree i have faith AMD will get things sorted
I've noticed a few retailers have motherboards due in today - namely MSI and gigabyte.
As much as an i7 suits my needs at the moment (1080p 144z) I am this closing to taking a leap of faith in ryzen in the hope they can sort these bugs out.
The jay2cents video was interesting, heaven benchmark was maxing one core of the ryzen and hardly touching the rest, whereas the i7 it was spread out equally.
Has anyone not had a 1700 reach 3.9Ghz?
I'm still torn between 1800x and 1700. Money not an issue as I'd already budgeted for the 1800x anyway.
In performance the 6900K is its competition, but it's priced at the 7700K level.
I've got a Gigabyte Gaming 5 on pre-orderEverything I've seen shows 3.9 is the minimum to hope for, even on the B350 boards.
Three weeks is the number being quoted in the industry, it was a super rush job, hence the current BIOSes not even being RTM quality.CAT - the mobo makers have had at least 1 YEAR to get this right! not 3 weeks
