*** Official Ryzen Owners Thread ***
Only just had a chance to start playing around due to an epic radiator fail yesterday :(
What temps are you getting? Also what temps were you getting at stock?
ON my 1800x @stock I have now got my Temps down from 50c to 40c
Someone please turn off 2 of the cores if possible and see if higher overclocks are achievable with 6 or even 4 cores, thanks :)
Now test it in real bench and watch it fall over :D
Though at that voltage you may manage...
correct it didn't like encoding haha
had to turn it down a wee bit..
going to have a proper play with it tonight once i get the bios updated and so on.
4Ghz is still nice ^^^^ turn some cores off if you can, see if it will OC higher with less cores :)
1700 - 10 mins runs with Realbench stress test temps with Noctua NH-U12S
The encoding H264 is the test that will find any weakness.
4Ghz needs 1.400v for complete stability with mine.
REALLY battling with the memory!
I can't even get 2400Mhz stable. And I have tried two sets:
1) 2 x 16gb rated 2800
2) 4 x 8gb rated 2400/2667
both corsair.
both corsair.
what mobo do you have ? i can get my corsair 32gb (2x16) up to 2666 but anything above that my pc starts sticking 2 fingers up at me. Although i haven't played around with the timings yet
Asus prime plus B350.
I can boot, cinebench fine, etc, but realbench kills it. Cpu at stock through this testing.
