Alreet guys
I will check in the loft shortly.Don't want to be a pain but if you have any 4-pin PWM fans could you try one in CPU 1 header. Set to PWM in BIOS, check smart fan box and set a fan curve and see if it works correctly or just runs full speed.
My bad. I have the same board coming tomorrow I'll let you know if mine is the same.No. The board has a CPU header and a seperate PUMP header. Even when connecting PWM fans to the PUMP header they work correctly and follow the fan curve.
Jumping into a few games including Arma 3, I am also finding that gaming feels smoother at 3440x1440. Also, after 30 mins of Arma my CPU temps was 47 degrees on air. Very impressed with this CPU.
Now where is my popcorn![]()
What's it a response too/about? (no speakers).
They mentioned their test results on a 5Ghz 7700k were much better than Jokers and that he was actually running a 4Ghz 7700K (not the stated 5Ghz of the video) and trying to pimp up AMD Ryzen results.What's it a response too/about? (no speakers).
I bet tech city (Brian I think his name is) feels a bit silly now.
I think he already did when he cut the heat pipes off a GPU and then wa dumbstruck the temps reached into the 90'sI bet tech city (Brian I think his name is) feels a bit silly now.
