Deleted member 66701
What version of premiere pro and after effects are you using?
I'm on a CC sub, so both latest 2017 versions.
I am currently still using the CS6 versions.....I'm on a CC sub, so both latest 2017 versions.
My 1700 seems to struggle at 3.9 :/ maybe the board I'm using b350 tomahawk but i know others here have had success.
at 3.8 1.29 is stable but 3.9 has had me go up to 1.375 and is still not stable, not sure I want to push it anymore. Not until my bracket arrives. Stock cooler not doing a bad job though, kept it under 70 degress even whilst doing 5 consecutive runs of cinebench.
3.8 is excellent do you really need 3.9?My 1700 seems to struggle at 3.9 :/ maybe the board I'm using b350 tomahawk but i know others here have had success.
With better cooling I think I would get to 4.3 with my 1800x.....Looks like you've just got a poor clocker.
So far the theory of the binning processing being almost entirely down to leakage is true. 1700s are hitting a wall at around 3.9-4ghz where they stop scaling with volts whereas the 1800x and having an easier time getting there
What sort of voltage do you need to push that far?With better cooling I think I would get to 4.3 with my 1800x.....
No not at all, the OCD in me wanted 4.0 lol. 3.8 is fine, I'm going to run stress tests for the next few hours.3.8 is excellent do you really need 3.9?
Is it wrong that I really like the look of the stock cooler? It might just be the child in me but when my corsair bracket arrives I think Im going to miss it.
Its helpful for the community...
I'm not going to run those tests...As they are meaningless....
And better and smoother is Subjective
So your point is MOOT
It's not MOOT at all. Just general use of my machine with Ryzen and even gaming feels much smoother than my 5820k. You don't need numbers to see/feel that.
When running at 4.2 i needed 1.37 so at 4.3 I think I would need anywhere between 1.37-1.45:What sort of voltage do you need to push that far?
I know what you mean, although im comparing mine to my old cpu which was a 3930k @4.2Ghz
All ready tested with 16GB of ram....
I am using Corsair CMK32GX4M2B3000C15 32 GB (2 x 16 GB) Vengeance LPX DDR4 Memory Kit - Black, I put them in the slots recommended by the manual. If you click the link in my sig you can see my setup....Are you using 2x16GB Corsair Vengeance @ 2400MHz? If so, are you using A2 and B2 slots?
