Great product.
Minor gripe with the listing:
#snip#
-Guaranteed 5g+ Core Overclock in all none AVX applications...
- None AVX Prime 95
#end snip#
I think you mean "NON AVX"
#snip#
- None AVX Prime 95
#end snip#
8 Pack;30416852 said:So here we have it, the first retailer in the UK selling binned Kabylake CPU's. The first retailer in the UK selling delidded CPU's with full OCUK warranty. No need to invalidate your warranty anymore or Bin CPU's locally!!!
The key features of this product are:
-Guaranteed 5g+ Core Overclock in all none AVX applications. All games and most professional applications are non AVX.
- CPUs binned by myself and delidded by our technicians with Liquid Metal replacing original Intel TIM for upto 30c cooler running temps.
- Full 1 year warranty with OCUK
- Free Thermal Grizzly 1g TIM so as to get the best thermal bond with your heat sink and hence great cool running.
The components used for binning these CPU are as follows:
Asetek 240 AIO cooler (We suggest at least this level of cooling for efficient stable operation)
3200mhz 16gb Corsair dual channel Vengeance mems at XMP
Nvidia GTX 1080
Asus Strix and ROG motherboards and Gigabyte Gaming 7.
1200w Quality Gold PSU.
Stress tests used:
Real Bench stress test.
None AVX Prime 95
XTU CPU stress test with 3D running (Heaven or Valley Maxed out!!!)
Suggested settings for 5g:
- Vcore 1.32-1.39v load typically 1.35v needed at most.
-VCCSA 1.00 -1.10v for 3200mhz mems Upto 1.25 for DDR4000mhz +
-VCCIO 1.00-1.10v for 3200mhz mems. upto 1.25 For DDR4000mhz +
+warranty upto 1.425v load if you want to push further.
The hardware we recommend to get the best from these CPU is:
Motherboard in ASUS Strix, ROG range or Gigabyte Aorus.
AIO cooler with 240mm Rad or higher, lesser cooling may work fine but is not guaranteed to.
Quality Bronze rated or above PSU providing enough quality power for the entire system.
Here is the link to this power users product:
https://www.overclockers.co.uk/inte...a1151-pre-binned-processor-oem-cp-003-oe.html
