A service is never just a service is itBMW tell me I need new front discs too (although the pads are only 55% worn the discs themselves are below recommended min). So £450 brake discs and pads, £150 oil service (expected) plus whatever I spend on tyres, this is going to be an expensive car ownership month
Lucky they included a free vehicle check
The glove box catch is broken too (stuck in locked position) but at £200 to fix I can live without a glove box for a while...
Yeah, was on about the warranty beyond the the one that comes with a AUC. So it is possible then?
Weren't you definitely replacing the car by September? What I've learned is that when a BMW main dealer say things are "recommended" to be replaced - it really means they're about half worn. If you're not able to tell if your discs are worn yourself, I would take it to a local garage for a second opinion. Unless they're really bad, I would suggest that they can wait a few months for them to be the problem of the next owner - saving you £450.
If you absolutely do need discs - why take it to a main dealer? Brembo discs and pads are £196 from EuroCarParts and fitting should be....£60-70? A saving of £200 - or a nice weekend away somewhere!?![]()
Wouldn't I need genuine BMW parts to maintain the extended warranty? Glovebox they'll do under warranty but I pay £100 excess, maybe they could throw that in FOC. Could poor alignment cause that kind of tyre wear or under inflation?55% Worn Front Brake Discs and Pads Required - Discs are worn well below min recommended thickness
rear left tyre needs replacing: 2mm inner tread depth, 5mm middle tread depth, 4mm outer tread depth
rear right tyre needs replacing: 1.6mm inner tread depth, 4mm middle tread depth, 2.5mm outer tread depth
Reads like both alignment and over inflation to me.Yes, you can here: https://www.bmw-warranty.co.uk.
Hope to sell it by September (earliest) but that depends on a couple things going right... Second opinion is a good shout, the BMW report says, in the "red-urgent" section: Wouldn't I need genuine BMW parts to maintain the extended warranty? Glovebox they'll do under warranty but I pay £100 excess, maybe they could throw that in FOC. Could poor alignment cause that kind of tyre wear or under inflation?
Yes it's trivially easy for a dealer to do this but some don't seem to realise so might claim they can't do it.
New BMWs have a 3 year warranty anyway...Thanks. I'm sure I've read people negotiate this at the dealers, but might have been for brand new cars. I'll call them up tomorrow and ask them again.
Call me a *****, but I wouldn't be replacing either of those rear tyres either. I'd be getting it properly aligned, setting the pressures correctly and then keeping an eye on the inside edges. With the alignment set properly they'll wear away a lot slower than they have been.Yes, you can here: https://www.bmw-warranty.co.uk.
Sounds quite a lot.
Huge! The car has stiff suspension as is, never mind with 19s and thin rubber rings around them. It is less bouncy, doesn't feel as sketchy on the road and just handles and feels a million times better. As much as i like the look on 19s i will not go back to them. 18s with good fitment and more sidewall look and drive much better in my opinion.Grudas how big of a difference has going from 19" to 18" in terms of ride quality and comfort on your Z4? I'm currently on 19" CSL's from CM wheels which they do look gorgeous on the car, My wallet and spine could do with less of a pounding
Hoping to see a big difference with going from Front 225/35/19 Rear 265/30/19 to whatever size MV2's are.
they quoting 5.5k for a 0 mile recon replacement.
