The Athlon X2 and Pentium D arrived in 2005So its RIP dual core CPUs (2007 - 2017) on April 11th![]()
If I understand you correctly your saying that your perceptible performance feels no different when going from a 6700k @ 4.7 to a stock 1700X?
I'm thinking if making the jump from a 3570k myself. And was debating the gaming performance.
My Hero finally came in last night and I started putting things together. Can anyone tell me if there is supposed to be a seal on the Asus box? The one I got was not wrapped in plastic, or had not seals to keep it closed. Everything was in the box, and it looked unopened.
Before I re-install windows did a quick run on WOT this morning.
I do not see any difference in fps, maybe feels bit faster and doesn't freezes on shots with a lot of smoke. But that could be my perseption.
But for sure the fps is not less than the 6700K @ 4.7 if not more (1700X at stock speeds). And that's a single threaded game, with the audio processed on second thread only.
Testng Ryzen on the CPU Physics heavy area's in Crysis 3 with 4 GPUs. Previously my 5960x would drop some FPS in the grassy area's.
Any juicy leaks about 1600x overclocking potential? Mildly concerned by it still being a 95w part, but the price is nice!
You're going to be disappointed if you fork out for the new shiny for improved gaming performance.
The best reason to buy one is for the work potential and have decent gaming potential on the side. It's plenty good enough for gaming but better than what you have... nah.
Is it really no better than a 3570k....
Matt, you state 4 GPU's but am I going mental or is it using just 1 of them?
We have confirmation from AMD that there are no silly games going to be played with Ryzen 5. The six-core parts will be a strict 3+3 combination, while the four-core parts will use 2+2. This will be true across all CPUs, ensuring a consistent performance throughout.
Yea someone else threw this at me in another thread. I highly doubt I wouldn't see an uplift in games going from a 3570k to a 1700X?![]()
AT thinks that the R5 1500X has 16MB of cache and the R5 1400 has 8MB of cache:
http://www.anandtech.com/show/11202/amd-announces-ryzen-5-april-11th
So it seems the R5 will be a dual CCX design.
When you try to scan or download updates through Windows Update, you receive the following error message:
Unsupported Hardware
Your PC uses a processor that isn’t supported on this version of Windows and you won’t receive updates. Additionally, you may see an error message on the Windows Update window that resembles the following: Windows could not search for new updates An error occurred while checking for new updates for your computer. Error(s) found: Code 80240037 Windows Update encountered an unknown error.
Cause
This error occurs because new processor generations require the latest Windows version for support. For example, Windows 10 is the only Windows version that is supported on the following processor generations:
Because of how this support policy is implemented, Windows 8.1 and Windows 7 devices that have a seventh generation or a later generation processor may no longer be able to scan or download updates through Windows Update or Microsoft Update.
- Intel seventh (7th)-generation processors
- AMD “Bristol Ridge”
- Qualcomm “8996"
Resolution
We recommend that you upgrade Windows 8.1-based and Window 7-based computers to Windows 10 if those computers have a processor that is from any of the following generations:
I understand how Windows 7 would not be updated going forward, but Windows 8? Really?? It has standard support from Microsoft until January 2018.
- Intel seventh (7th)-generation "Intel Core" processor or a later generation
- AMD seventh (7th)-generation (“Bristol Ridge") processor or a later generation
- Qualcomm “8996" processor or a later generation
I don't know about anyone else here, but I love Windows 8.1 with Classic Shell. It has everything I need out of a Windows OS, however when it comes to Windows 10 it just feels wrong in some way to me.
Personally I'm still going to be running Windows 8.1 even when I get my Ryzen rig. Thanks Microsoft for another XP-era!
Anyone else have any thoughts on this?
This is a bit of an epic fail by Microsoft. First they make Windows 10 Anniversary update a mandatory update despite it causing fairly widespread issues, then they block people with Kaby/Ryzen CPUs from using anything else. GG Microsoft, GG >.>Looks,like MS is now blocking Win7 updates if you install Ryzen or Kaby Lake.
