- 14 Oct 2007
- newcastle
Got to love when your trying to set your ram and you get an error code that isn't even in the book error code 8 not 08 like in the book
Yes ofcourse higher memory speed on these cpu is like extra 200Mhz performance..Imc and cpu all working harder so extra heat. I also noticed this amd it's normal.Also can changing ram change the load temp? Yesterday I was at 3.9 stable no more than 62c since I have put the new ram in it now shooting up to 70c then crashing, I have reseated the the AIO twice so I don't think I have knocked anything, it is definitely getting hot because I can feel the heat in the tube
Ok I'm officially confused.
Had my CH6 arrive today, also got my Corsair Vengeance LPX 16GB 3200 arrive.
Spent over an hour tonight trying in vain to get the machine to POST on anything more than 2666mhz.
I've got the sticks in A2+B2, but setting the profile in the BIOS to 3200 or even 2900 results in no POST, tried setting voltage as high as 1.5v too but no dice.
Any clues or hints please?
New Crosshair bios has got me back up to 3200mhz and 1T command line
New Crosshair bios has got me back up to 3200mhz and 1T command line![]()
Can someone recommend so high airflow low noise fans please
Naw I need something more on the quite sideNot quiet but best ones imo are industrial noctua's, I'm cheap so have akasa viper's
Thanks, I'll be looking for 4ghz when my am4 bracket comes because......even numbers are betterNice work mate.
Corsair LPX CMK16GX4M2B3200C16 - They are single ranked but Hynix chips so not the ideal mix but doing ok. Had to run 2T and 2666mhz on the 0902 bios but can get 3200mhz on 5803 and 1001.What RAM you using if you don't mind?
the high speed pwm silent wings 3 are supposed to be goodCan someone recommend so high airflow low noise fans please
Thanks, I'll be looking for 4ghz when my am4 bracket comes because......even numbers are better. Got some PK2 for it as well
Good luck!
noob as well but I understand it to be a interface line. it can run at two different timings (1T and 2T). Ryzen and most processors prefer 1T but the latest official asus bios (0902) forced 2T to get more RAM types to work abate at a slower rate. Would probably only notice the difference in benchmarks though. So they are offering two bios now, the normal 1T but if you are having memory problems you can try the 2T one to give yourself a bit more leeway.sorry for the noob question but can u explain the 1T command line please, iv seen it mentioned a few times, thanks.
their offering 1t and 2t bios's on asus boards or are other boards getting that too, thanks for the infonoob as well but I understand it to be a interface line. it can run at two different timings (1T and 2T). Ryzen and most processors prefer 1T but the latest official asus bios (0902) forced 2T to get more RAM types to work abate at a slower rate. Would probably only notice the difference in benchmarks though. So they are offering two bios now, the normal 1T but if you are having memory problems you can try the 2T one to give yourself a bit more leeway.
Just the crosshair so far. For 0902 they forced 2T for everyone because you could get better compatibility for 2x16gb and 4x sticks. But this knocked down some guys overclocks and had the issue of loosening timings so this time around they just gave out two types to try and please everyone, with the idea that if the 1T file didn't work they could load the 2T and see if that helped them whilst still having the improvements from 0902.their
