DubsCan't even see the score bud, it's so tiny.
Stick memtest on a usb stick and run that. Should take around 4 hours.Crashed again. Everything at stock. Looks like I've got a bum chip\mobo or ram. Off to the CS forum I go, looks like Ryzen will be going back.
Don't know what's going on with pictures I post, the
Score is 1660
I'll see your 1660 and raise you 7
I'll see your 7 and raise you 184.
What memory?Aye but mine is at 3.8
3200What memory?
Was that to me?How much did you pay in total for that kind of set up?
3200
This, works fine on 1001What memory is that? I'm looking to upgrade mine. 2933 seems to be the limit. And even then it's sketchy
http://www.memtest86.com/download.htm
Good to hear mate. What voltage are you looking at? For me it seems i need 1.44 for a 3.9 :/Further update guys.
Team Groups had errors on them after testing. Just installed some Corsair Vengence form the QVL and system is running. Now working on clocking, got a dirty 3.9 but the volts are too high so going to work on reducing them now.
Thanks for all you help with this.
Anything needing 1.4v for me is just too much power usage for too little gain.
Great little chip I've got here it seems. Will try for more soon.
