The Pascal GTX 1080 Ti Owners Thread
the boost clock seems low only 1683Mhz only 6% over factory, but i guess it boost further. easier to get it right from any chip i guess
memory clock 1376Mhz? wtf? do they mean 13376Mhz? or 11376Mhz big difference
1376 * 8 = 11008 is the most likely memory clock. Firestrike uses a similar measurement for runs. Stock run on 1080Ti showing memory at 1377 = http://www.3dmark.com/3dm/18564739? which equates to just over 11,000 Mhz on the card.
Those clocks must be a mistake?
Look right to me. Cards will boost well past that anyways so its a moot point mostly. Also doubt they want to see the Fiasco that hit the ASUS OC model where they binned chips so high, only a small sample could actually do that speed.
Welcome and on TROH.:)
The Roll of Honour.
Date 22/03/2017, Make EVGA Founders Edition, Razor Time, Link
Date 21/03/2017, Make Zotac Founders Edition, Andy321, Link
Date 21/03/2017, Make Zotac Founders Edition, Radeon85, Link
Date 21/03/2017, Make Zotac Founders Edition, epc1, Link
Date 20/03/2017, Make Gigabyte Founders Edition, AstinGC90, Link
Date 19/03/2017, Make NVidia Founders Edition, BaDBoY_uK, Link
Date 19/03/2017, Make NVidia Founders Edition, ChrisD, Link
Date 18/03/2017, Make EVGA Founders Edition, Tommy_Here, Link
Date 18/03/2017, Make EVGA Founders Edition, ntemples1, Link
Date 17/03/2017, Make MSI Founders Edition, Rossi~, Link
Date 16/03/2017, Make Gigabyte Founders Edition, Ayahuasca, Link
Date 15/03/2017, Make Zotac Founders Edition, Sem, Link
Date 15/03/2017, Make Zotac Founders Edition, Gripen90, Link
Date 15/03/2017, Make Asus Founders Edition, ZeroG, Link
Date 15/03/2017, Make NVidia Founders Edition, atomic7431, Link
Date 15/03/2017, Make NVidia Founders Edition, Glanza, Link
Date 14/03/2017, Make MSI Founders Edition, Choimaloy75, Link
Date 14/03/2017, Make MSI Founders Edition, rtho782, Link
Date 13/03/2017, Make EVGA Founders Edition, tyler_jrb, Link
Date 13/03/2017, Make EVGA Founders Edition, Radox-0, Link
Date 12/03/2017, Make EVGA Founders Edition, Dicehunter, Link
Date 12/03/2017, Make NVidia Founders Edition, The Artfull Bodger, Link
Date 12/03/2017, Make EVGA Founders Edition, khemist, Link
Date 12/03/2017, Make EVGA Founders Edition, dnic77, Link
Date 11/03/2017, Make EVGA Founders Edition, trawetSluaP, Link
Date 11/03/2017, Make EVGA Founders Edition, Xereo, Link
Date 11/03/2017, Make EVGA Founders Edition, madindehead, Link
Date 11/03/2017, Make EVGA Founders Edition, Techen, Link
Date 11/03/2017, Make Asus Founders Edition, bemaniac, Link
Date 11/03/2017, Make EVGA Founders Edition, deFiniLoGy, Link
Date 11/03/2017, Make NVidia Founders Edition, roysters, Link
Date 11/03/2017, Make EVGA Founders Edition, Mean Mr Mustard, Link
Date 11/03/2017, Make Zotac Founders Edition, sk3lph, Link
Date 10/03/2017, Make NVidia Founders Edition, stooeh, Link
Date 10/03/2017, Make NVidia Founders Edition, IT Troll, Link
Date 10/03/2017, Make NVidia Founders Edition, RichardH754, Link
Date 10/03/2017, Make NVidia Founders Edition, RichL, Link
Date 10/03/2017, Make NVidia Founders Edition, traveyb, Link
Date 10/03/2017, Make NVidia Founders Edition, Amatyr, Link
Date 10/03/2017, Make NVidia Founders Edition, X-Mikuru_Beam-X, Link
Date 10/03/2017, Make NVidia Founders Edition, Robzere31, Link
Date 10/03/2017, Make NVidia Founders Edition, Speed, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080 Ti.
Aha so if i want nvidia brand the only way to get it is from nvidia site ye?
Why would you want that? Nvidia use digital river as their retail agent and they are rubbish. The actual card is the same no matter what name is on the box and if you get the OCUK own brand one it is supported directly by OCUK, which is definitely a step up from digital river
I bet they'll try to charge £899 for it. After that reveal of the clocks,my son is now looking at MSI Gaming X or the Asus Strix OC instead? Not impressed with the EVGA cards :(
Also very much not impressed. I'm now looking at the Asus Strix and Zotac Extreme (when those specs are conformed).
SR2 480 Push Pull + SR2 360 Push fans at 800rpm and it reaches 39c after an hour or so
what kind of rad setup you have
I can't remember the specific models, but I have an EK 420 and an EK 360 I believe. Also in the loop is my CPU. When I had two Titan's in SLI they didn't get above 50.
What's the highest memory clocks you guys had running on these? I've just benched at +700 and seems fine which is 12400mhz effective.
The Roll of Honour.
Cheers :)
In my own testing the majority of games will prefer a +620 clock, I can prove valley runs better with a +700 clock but it does not stress the card hard enough for it to be a valid test. I would suspect that if you run 3DMark in 1440p or higher you can also demonstrate the same behaviour I.e you can set +700 but the bench will be slower due to vram error correction.
Lets not go there, my Titan X Pascal sat here, faulty, still waiting an RMA number 3 weeks on. They wasted 3 hours of my life on webchat trying to diagnose it even though I said I have two of them in SLI, one has died, tested in both slots, swapped power connectors etc. It is dead, yet they insisted on going through their check list of things to try. At which point they said they'd get back to me.
I am not too worried as I shall just contact NVIDIA directly but yes the people they are using well leaves a lot to be desired. :(
