This board takes unusually long though never seen this before
Edit the POST wait time in Boot menu, by default it is set to wait 3 seconds before doing anything.
Mine definitely doesPOST takes 4* longer than loading Windows.
Will try that, thanksEdit the POST wait time in Boot menu, by default it is set to wait 3 seconds before doing anything.
My fans seem to be stuck at 1300~rpm if I use case fan 2 (I think). They are plugged into a PWM hub. If I plug them into the cpu header they are stuck at 300~ rpm.
So for the time being I have unplugged one fan from my hub and plugged that into my cpu header and the rest into case fan 2 but I still get a fan error when it boots up which requires me to go into the bios to clear :/
Reading around the fan control is a bit broken at the moment and I think I saw something about an issue being fixed in the next bios.
I have tried with the single fan plugged into the cpu header in both DC and PWM and saw the same issue. No matter what I do with the fan curves there is no change in how they act. Temperature also makes no difference to the RPM.
Do you have the latest bios?Anyone else having fan trouble with their C6H? I replaced the stock fans with Corsair ML120's and they don't seem very controllable, when I run the optimisation utility in Fan Xpert it only reads being able to go at exactly 1k rpm, not all the way up to 2k or any lower.
I've tried reinstalling it a few times already to see if that will fix it without any luck.
PLEASE HELP
Sorry I meant I have tried both 4 and 3 pin fans (all my normal ones are 3 pin plugged into the Phanteks PWM hub) with the same outcome but I think there are some issues with the bios when it comes to getting the qfan thing working correctly the first time so that may of caused the 4 pin not to work. I am sure I have read something about it not working correctly with 3 pin fans at the moment.
Just buy an AM3 backplate off of Amazon or whatever. Mine is running great.
I tried this but it wasn't a god fit temperatures were way too high
Done this set the time to 0 secEdit the POST wait time in Boot menu, by default it is set to wait 3 seconds before doing anything.
It still takes about 20 secs to post anything ,![]()
