Meh, im ****** if I know lol. I've just reset cmos and changed nothing but pstate0 not even the voltage. Got into windows, locked to pstate 1 @ 2700 :/
Why can't we have cool n' quiet like the old days lol
Thanks man, I'm sure its something really stupid.Going to look at this now and report back
You need to enable and set an Offset voltage on the Vcore, then it should work if you made no other changes.
I tried both offset and default voltage, pstate 0 does not want to play. pstate 1 is locked on it seems.
Right, offset set on the Core (which was a dirty to much than needed) but P 0 @ 99 (3.85ghz) is working ok for me. I did do a load default, save BIOS then go for the p state change.
Matt, 1.4V safeish for 24/7?
Atta boy! Yes, anything 1.4v or under is perfectly safe. You could probably go higher without issue, say up to 1.45v.
As I've been playing most of the day, looks like 1.417v for 4Ghz. What do you think @AMDMatt?
edit:I have to add, this is just what I was after. Just like Intel Speedstep, ramps up when needed.
Scrub that, she's not quite stable. May need a little more juice or knack her down on the clocks.
Right, I've now sorted it. The VID in pstate0 was set to 20 (1.35v) even after a cmos reset. I manually changed it to 3A and set my offset from there.
It is now clocking down to 1500mhz at 0.8v Happy days.
At the moment I'm at [email protected] I have tried 1.44 for 4.0 but it was unstable. I dont think going an extra .1 is going to help that
I'm going to order some 3200mhz ram and call it a day I think. I'm sick of seeing this damn BIOS!
On a side note, setting the bus any than 100 results in a crash, even at 102. Is this down to memory also? I'm leaning towards that because I can boot at 2933 but its very flaky but 2666 is perfect.
Further update. Settled on a 3.9Ghz via P State config. Been running 4.9 all day, volts are much less than if I tried pushing for 4Ghz - I'll never notice that 100mhz.
Thanks again for all you help @AMDMatt
I can't get 3.9 on mine at anything below 1.42v, it's nice and cool no higher than 56c on prime small ffts, I must just have one of those chipsCan you not get 3.9Ghz @ 1.35v? 1.4 seems a little high
