Just reporting in on my tinkering today,
1700X @ 3.9Ghz on Asrock Taichi, offset voltage 7500 ends up as 1.376v under load (LLC set to Auto)
2x16Gb @ 2933 18-20-20-40 1.375v SOC 1.1v
Had a bit of struggle trying to hit 4.0Ghz stable so given that up for now and was working on RAM speeds, currently 2933CL18 is my limit with this 2x16Gb 3200CL16 kit. Not sure what the max safe SOC voltage is, pumping it to 1.1v from 0.9v helped a lot, I think I've seen people at 1.2v but not sure if that's safe for 24/7 usage?
http://valid.x86.fr/0z7ely
Asus have previosuly said that SOC voltage should not exceed 1.2
What voltage were you trying 4.0 at?
from a 3570 it's going to be at least 500, CPU, board and ddr4 memory.
... Re missing ...Its there system so there responsible...
