Thanks.
Do you have any links for the watercooling for the 240 case only I've struggled to find anything in the past? I've not really looked into it for a while TBH as I thought the lack of space may be a problem.
There's a really tidy hardline one here:
https://www.reddit.com/r/watercooling/comments/2lpd02/build_complete_corsair_air_240/
http://imgur.com/a/i4svY
And another here (although not a fan of white builds):
http://forum.corsair.com/v3/showthread.php?t=135683
Which look to use an EK res/pump combo DDC PWM (prob the 100 looking at the size of the res). You can fit a fair old amount in the 240 - you should (although you'd have to have a workout with ram height and the top vent vs slim rads and fans) be able to fit 2x240 rads in there. I've built a mitx wc build in a Fractal Nano S (bit of a rip-off of Pauls one, have re-done the tubing as was in a rush haha), and although tight, works well:
Can't seem to upload iages, so's here:
http://imgur.com/a/aGRFl
