Jetway were actually good in the mid 90's unless you were clocking the nuts off a CPU, much better than the joke they became.Jetway motherboard![]()
The new recommended minimums for a gamer are thus:
8 cores are the new 4, 16Gb of ram is the new 8Gb and 8Gb of vram is the new 4Gb
I agree with him. Which is why I went and bought a Ryzen 7 cpu. I noticed that the recommended cpu specs for recent AAA games where advising i7's and AMD 8 core parts (FX)... which are quite apart in performance but I deduced from this that what their saying is 8 cores is the most important part.
This is also why I recently said that 1070 is actually now a 1080/1200p card.
Don't question me on this until you've watched the video.
Anyone care to take a wild guess on when the gigabyte boards will arrive? the wait is killing me![]()
And that has zero use, because no one pairs a high end GPU with a high end CPU to game at 1024x768 or 1280x720P.
Ah interesting, a while back the gigabyte twitter said by the 2nd week of April so that seems to match up. Thanksthe rain forest told me another 10 to 15 days that was 2 days ago
But that wasn't the point. The point was to "try" to put the CPU in a couple limited situation to see which "may" last longer. Clearly from AdoredTVs analysis, the test didn't match reality. However, the intent is there regardless of if it was a worthwhile test.And that has zero use, because no one pairs a high end GPU with a high end CPU to game at 1024x768 or 1280x720P.
All they are trying to do is see how much grunt the CPU has when you take the GPU out of the picture as much as possible. That was the assumption anyway. Clearly, AMD's chips have bucked the trend.
What this shows me is again.... AMD is always pushing tech too early. Although... they certainly do give themselves longevity by increasing performance over time.
When you run in such an artificial way you're not really testing gaming, you're trying to make a game act like a CPU benchmark. But it's not, which makes it entirely unreliable for that kind of thing. You need to test games at realistic settings, or we may as well argue to test at 1x1 (yes, 1 pixel by 1 pixel).
I was ready to write a big message but going stick to your snobbery of the "AMD is always pushing tech too early". Which is hypocritical.
What you wrote applies the same to the 6800K/6850K/6900K/6950K/5960X etc. Because their performance at your 720p "ultimate CPU grunt testing benchmark" going to be worse compared to Ryzen due to weaker IPC. And those CPUs are far more expensive.
Or the "anti AMD bias" only matters for you?
(FYI I have a 6800K before you call me an AMD evangelist)
muahahahaDead pixel on a 1 x 1 display is a killer.
), and the 6800K I see no need to overclock, but have done that to 4Ghz for 24/7.
I am so confused by your comments.
Don't be pedantic. I asked you to clarify for God sake.Pointed that your comment about AMD applies to Intel Enthusiast lineup also. But you ignore the point by getting confused.
muahahaha
Seriously guys, at 2560x1440 I am gaming, realised that the quad cores are the bottleneck and need more Ghz to run.
The 6700K had to be overclocked to 4.7Ghz to play World of Tanks (single thread game) at 2560x1440 and still there, the GPU wasn't running at 100% all the time.
Trying to watch a video on youtube on the second monitor was a no go, and had to keep it minimised.
Reason, is only 4 cores and are getting cramped with services to run.
Both with the 1700X (which I owned briefly), and the 6800K I see no need to overclock, but have done that to 4Ghz for 24/7.
The overall performance of the system if far better, can play WoT, the card is working at 100% generating more fps, and on the second monitor I can watch eg Lisa Stanfield videos at high resolution without taking the perf.
When Easter goes through, going to grab another Ryzen, but contemplating waiting the 16c one also![]()
Quite a boost from just a game update.
Ashes of the Singularity Gets Ryzen Performance Update | PC Perspective
https://www.pcper.com/reviews/Processors/Ashes-Singularity-Gets-Ryzen-Performance-Update
