Was thinking for vm's it would run better with more cores and threads ?
As each machine I use has 2threads and 2 cores and 4 gig .
Has anyone seen any performance comparisons running the C16 vs C14 ram? I'm looking at the Trident Z 3200 stuff but there's a pretty substantial price jump between the two.
His results do not match those of mindblank nor joker or even computerbase. Which goes back to the adoredtv review. Any reviewer can make the results look good or bad. I don't know who to believe anymore.
But at least joker and mindblank show you video footage with msi afterburner running and frametimes. This guy just shows a graph and expects people to believe it.
From a bit more digging, the C16 stuff is dual rank where the C14 stuff is single rank. People have been having a lot more success getting the rated speeds out of the single rank kits.
Yes. More cores and threads will make a big difference. But going from 2666MHz to 3200MHz will gain a marginal boost, I would think (subject to edge cases). I mean what are you using these VM's for? If it's development purposes to simulate client-server for example, I would not expect any noticeable difference because most of either will be idle during development loads. If you were doing something bonkers like using one of the VMs to render images on the other hand, - yes, it might make a more noticeable difference.
But in general performance follows this path of significance.
-->RAM size (hugely important if not enough, unimportant once past that)
--> GPU (if gaming)
--> Cores + Threads (+ FPUs in specific cases)
--> Disk Speed
. (large gap here)
-->RAM speed.
I do development work with multiple VMs (usually just two or three) and I'm not concerned by the difference between 2666 and 3200.
Thanks wish i could afford RGB sticks but £400ish not a chance . Was looking at these Corsair Vengeance LPX 32GB (4x8GB) DDR4 PC4-25600C16 3200MHz Quad Channel Kit - White (K32GX4M4B3200) ?
Thanks.
It doesn't even match Level 1 Techs, LegitReviews or PurePC
Hardware Unboxed is the exception to the majority at the moment. Then you have his fans stating things like Ryzen 20% slower in gaming and another Bulldozer, yet the majority of reviews disagree. Many of those reviews even include Ashes of the Singularity, and Total War that recently got updates, Ashes got +31% and TW got +10% in FPS.
Techpowerup had the largest set of games tested, more than many reviews combined.
Things like this will always happen, people will always try to justify their purchases. I'll stick to watching people showing us live footage with MSI afterburner running so we can all see what is happening.
Looking at their results though, that chart is for CPU tests (probably no games). If you look at the other graphs that are specifically gaming at 1080p the 7700k is 12% faster. At 1440p the 7700k is 5% faster.
Lose 12% gaming performance but gaining a platform that will be supported for the next 4 years and with double the cores and threads its pretty much a no brainer. I think some people are scared of change, what people are forgetting is this is good for everyone. Its also fun how nobody is mentioning the gaming performance of the 6800k....... When that came out it was just accepted, yet look how ryzen has been portrayed.Looking at their results though, that chart is for CPU tests (probably no games). If you look at the other graphs that are specifically gaming at 1080p the 7700k is 12% faster. At 1440p the 7700k is 5% faster.
