Ah right. I'll turn that off in the settings.Think your find that it's part of the wake on Lan
Thanks
Can someone tell me if this board supports P-state overclocking?
Also, does anyone run Corsair cmk16gx4m2b3000c15 successfully @2933mhz?
I posted this in the Ryzen thread but it's applicable here too:
Just found this randomly. It's a quote from someone that works for AMD saying the April Bios update should start hitting boards from April 11th and it should help get ram up to 3200Mhz....With another bios to come in May.
Try setting speeds yourself. It seems when you use docp, it defaults to 1t, but doing self seems to leave on 2tThe new bios has done nothing for my memory, I still can't get past 2666 mhz on DOCP.
It has a new feature under RGB where you can choose to have the RGB lights off when the PC is off.
Thanks will try it.Try setting speeds yourself. It seems when you use docp, it defaults to 1t, but doing self seems to leave on 2t
Was just coming to post. You guys f5'ing the page constantly?
I'm down to just a few times a day myself
And just after got everything running at 4ghz...
Oh well, first thing to try is the ram.
Well, i could get into windows with 2666, do some cinebench runs, but aida64 killed it.
That took putting the dram voltage up to 1.425v though :/
Still, obviously an improvement on before.
