Ok I got it, hopefully it reduces even more in the next month so I can price match it.
With the latest update to the B6 what is the input lag for gaming now?
Input lag after the latest update is 28ms now on the B6.
That's really good i never knew JL did that, shame i don't have one near where i live unfortunately i can only order online.
I hope they come down just a tad more £1500 and i'll buy one right now.
That's brilliant!
How is the HDMI-CEC on the LG, I found it it worked 50/50 on the KS7000 I had but that TV has lots of issues. Ive since turned this feature off on my current Sony but if it works as intended on the LG b6 I might use it.
HDMI CEC is working fine for me on the LG it works with my Denon x2300 av amp /PS4 PRO and samsung 4K player no problems.
Good to hear, although I may just disable it altogether, I use a optical cable for the tv sound and built in apps for sound to my bar. I don't mind just turning on stuff separately.
Already tried this, they weren't interested in matching JL at £1799 with the soundbar. They were only matching without.I was about to purchase this T.V at £1799 yesterday as i was trying to get John Lewis or Richer sounds to do it for £1799 but match Curry's deal where they throw in a free soundbar.
Got told by the manager at currys some instore deals will be showing on Thursday so i'm waiting till then see if i can get it any cheaper personally.
I got this TV for £1500 back in Jan. One of the best purchases I have done in a long time. If anyone can find it for this price compared to at least double the amount for the 117 models. Then buy without thinking.
Does the sound bar support HDMI ? if so you could use ARC then you would not need a optical cable.
It does, its a Yamaha YSP2700, I guess I could try it out, I just had a few issues with it on the KS7000, which put me off using the feature.
Ah ok i see well maybe you will have better luck with the LG![]()
Does hdmi arc work still with hdmi cec off on the b6, simplink I think it's called?
Thanks
I dont think the audio would work with CEC turned off.
TV arrived this morning, damn that's a big box.
The price has dropped another £100 on Currys website. Does anyone know how many times you can get a price match with JL? If they drop to £1699 themselves and I get £100 back, can I claim any other price drops that happen in a week / 3 weeks?
Got this TV, Have standard Xbox One, do I need to change video settings from 8bit to 10bit?
Thanks
10bit for HDR support i believe.
Thank's, I had it on 10bit on the KS7000, just wanted to be sure its the same.
I also am a bit unsure about some settings in advanced video settings, there is two boxes stating allow 24hz and 50hz for games and apps. Should these be ticked.
