Picked up a LG OLED55B6V
That's really good i never knew JL did that, shame i don't have one near where i live unfortunately i can only order online.
I hope they come down just a tad more £1500 and i'll buy one right now.
That's why I tend to buy from them only, prices can move a lot in 28 days, other places like Richer Sounds are good but I think they only do like a 7 day after purchase and only up to a certain amount.
Input lag after the latest update is 28ms now on the B6.
That's brilliant!
How is the HDMI-CEC on the LG, I found it it worked 50/50 on the KS7000 I had but that TV has lots of issues. Ive since turned this feature off on my current Sony but if it works as intended on the LG b6 I might use it.
That's brilliant!
HDMI CEC is working fine for me on the LG it works with my Denon x2300 av amp /PS4 PRO and samsung 4K player no problems.
Good to hear, although I may just disable it altogether, I use a optical cable for the tv sound and built in apps for sound to my bar. I don't mind just turning on stuff separately.
Does the sound bar support HDMI ? if so you could use ARC then you would not need a optical cable.
I was about to purchase this T.V at £1799 yesterday as i was trying to get John Lewis or Richer sounds to do it for £1799 but match Curry's deal where they throw in a free soundbar.
Got told by the manager at currys some instore deals will be showing on Thursday so i'm waiting till then see if i can get it any cheaper personally.
Already tried this, they weren't interested in matching JL at £1799 with the soundbar. They were only matching without.
I got this TV for £1500 back in Jan. One of the best purchases I have done in a long time. If anyone can find it for this price compared to at least double the amount for the 117 models. Then buy without thinking.
Are you the same person on HUKD who keeps saying they got this for £1500 but no one knows how? :P
I dont think the audio would work with CEC turned off.
Thank's, that's what I thought.
Because I want a Harmony remote soon as well I have decided I will turn Simplink off and just add in a optical cable for sound from TV. Will not lose anything like this as I have my devices connected directly to my soundbar anyway, the optical will only be for sound coming from the TV tuners or any built in apps I may use.
TV arrived this morning, damn that's a big box.
The price has dropped another £100 on Currys website. Does anyone know how many times you can get a price match with JL? If they drop to £1699 themselves and I get £100 back, can I claim any other price drops that happen in a week / 3 weeks?
I imagine it will be as many times as possible within 3 weeks as you could just easily return it and get it cheaper else where, I would contact them though in case they have some sort of policy against it like you can only claim once or twice for e.g.
Just purchased the T.V and i can't seem to find Game mode HDR. Tried looking for a firmware update via T.V settings while connected to the internet and it says no update found.
My firmware is 04.30.65 but the latest one that includes Game mode HDR etc is 04.30.95.
After downloading it to a USB stick i'm having troubles unzipping it as it says "The archive is corrupt" Any ideas?
Thank's, I had it on 10bit on the KS7000, just wanted to be sure its the same.
I also am a bit unsure about some settings in advanced video settings, there is two boxes stating allow 24hz and 50hz for games and apps. Should these be ticked.
Yes tick them both 50hz is for uk content 24hz is for movies from blu-ray
