- 17 Mar 2017
- Manchester
Sexy build you have there![]()
Thanks buddy.
http://www.tweaktown.com/reviews/81...1080-ti-amp-extreme-edition-review/index.htmlTweaktown full review of the amp extreme, reckons it's the best of the customshttp://www.tweaktown.com/reviews/81...1080-ti-amp-extreme-edition-review/index.html
Best, but still only hits 2050 stable like a founders card
You wont see meny 1080ti`s that hit 2100+ speeds consider those golden samples... and even then they will run into power limit without a shunt mod......
For all others fe`s or aibs those will do around 2037-2050 speeds pretty much... and those are great samples.... and most of them will do that... without shunt mod and hit power limitations just sometimes..
as for memory on the GDDR5X = most TI`s will reach the 12gb per sec bandwidth my 2x gigabyte fe`s do 2037-2050 with memory at 500-550+ on msi afterburner....
Also some good news, when memory is overclocked on the 1080ti`s it really does improve performance....![]()
Yes but 67c and quiet.
Shouldn't you look at an overkill psu that won't need a fan spinning then silence!plenty of other cards are quiet, so being "the best" but not overclocking any further or being appreciably quieter than almost any other custom model
my only reference to the reference model was that all these magic power phases are not actually doing anything - most people buying the cheapest models will have headphones or water anyway - mine never goes about 55C and my power supply is the noisiest thing in my PC and my GPU sits at 2050 locked solid
Same here. As long as it can maintain 2Ghz+ then I'm happy
I can live without that 0.1 extra fps![]()
Yeah, a watercooled Founders Card. No way could you plug and play a FE blower and sustain 2Ghz+ at any normal fan speed. For out of the box performance, there isn't much better than the AE.Best, but still only hits 2050 stable like a founders card
there isn't even a sound reading on that review, so how quiet is it compared to other models, lol
the only other 1080ti they've reiviewed is the MSI gaming, which they also didn't do a sound reading on and didn't even include any overclocking results!
and that also hit 67c on stock clocks funnily enough, strange coincidence that
I'm telling you this card is inaudible even when pushed.
That's good to hear, as that was the reason I ditched my brand loyalty to Asus. I love my 980Ti Strix, but I was hoping I could eliminate the tad whiring noise of its fans at full load by jumping to Zotac (not everyone wears headphones!)
Need my Amp Extreme badly!!!![]()
Yeah, a watercooled Founders Card. No way could you plug and play a FE blower and sustain 2Ghz+ at any normal fan speed. For out of the box performance there isn't much better.
is this to make us regret not preordering ?
