- 16 Mar 2009
The only thing i have used the firestorm software for is the lighting, i use afterburner, all i did was apply what settings i wanted then in the settings disable the startup with windows check box, that works for me, I've never had the firestorm software start with windows so maybe that's why i haven't noticed that software bug by the sounds of it.just use afterburner for clocking etc.
Can you change rgb to what you like then uninstall that software - think i did that with my msi gaming x 1070.
Edit- just read Adrian's post - that sounds better.
Sadly it seems I may have to do this, I wanted to use the Zotac software as I want to be able to change RGB colours on the fly but if I don't use start with windows it may work!
