Collected the MPS.
Intake pipe was loose and missing a clamp according to the repair man..
They fixed that and replaced the MAF sensor.
Seems all rite now
Well if I'm honest... Doesn't feel as fast. I put that down to the lack or torque.how are you finding it compared to your dmps(diesel mps)
It's dead simple.. get on with itAnyone else, sure, me, no. Can't begin to imagine the carnage which would somehow occur.![]()
Spring compressor. Pfft use towels wrap it around shock and undo the nut against a wall. Be a man
Apart from Acme, you have to NOT use any cloths.I see you bought the Porsche I was eyeing up for myself![]()
