- 21 Apr 2013
Morning! Any drivers I need to install as it's a fresh install?
I can't remember what I chose now. I don't think it had chance as when I knew it had worked I shut it down. Was a long day yesterdayMorning Beady.
What did you select:
And has windows updated since install?
- Use recommended settings or?
- Important Updates only?
Ideally, you would have picked important updates only.
Yes, or he could buy an adaptor - will find link.Ok great. Not sure what to do with the front case fan? Will it be ok without it?
Hehe - true.RAM I bought the 1600 MHz so would swap that to the 3000 so that's already basically bought. Looking at around 450.
Haha I can stretch to afford it, it's an upgrade that would keep me going for a few years so it may be worth it. That's what I'm trying to tell myself anywayHehe - true.
So is it 'only' £450...
Or is it - Christ, i've got to find £450!
